Old 10-14-2016, 07:31 AM   #1
ToniandSal's Avatar
Probably a dumb question, but after a year I am still learning...
How do I completely drain the fresh water from the holding tank? I guess I could turn on the galley and bathroom sink faucets and let them fill the grey tank, then take to the local campground dump station, but it would be easier if I could let the fresh water drain down the driveway. I am still a newbie!
2016 Forester 2291S Class C
2016 Jeep Wrangler
Dana Point, CA
ToniandSal is offline   Reply With Quote
Old 10-14-2016, 07:36 AM   #2
Bowmanville SVT255S's Avatar
Low point drain
Look for a low point drain...If you can find it check your manual...If you can't find it use the out shower.
2015 Ram Crew Hemi
2005 Surveyor SVT 255RS
Bowmanville SVT255S is offline   Reply With Quote
Old 10-14-2016, 07:38 AM   #3
BamaBob's Avatar
Beat me to the answer by 2 min LOL
When we had our 5er, there was a petcock clearly labeled on the underframe "Low Point Drain" - just turn this and it will completely drain your fresh water tank
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 10-14-2016, 07:51 AM   #4
bubbles's Avatar
A low point drain is not a holding tank drain. Low point drains are supposed to be the lowest point in the water lines (could be one each for hot and cold lines) to allow expelling residual water in them. The holding tank drain is strictly for the holding tank. This is sort of standard but of course there is always the exception. The OP should be able to find a dedicated holding tank drain.
Old 10-14-2016, 07:54 AM   #5
Taranwanderer's Avatar
Low point drains don't necessarily drain your FW tank...they drain water that's already in your plumbing. To drain your FW tank, you'll need to find the FW tank drain, which will likely also look like your low point drain, but may be in a totally different spot under your rig.
Of course, if you're winterizing, you want to open both. But don't just open your low point drain and think you're draining your FW tank, it doesn't work that way.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20 (‘18)21 (‘19)23
2019 Honda CRV (camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 10-14-2016, 12:54 PM   #6
ToniandSal's Avatar
Not going to winterize it. There is still about 1/2 tank of fresh water I filled with a month ago for a short trip. Although I bought water fresh stuff at West Marine, I still haven't added it yet. We had some very warm days this month so I don't want to take a chance with bad water now.
Old 10-14-2016, 01:22 PM   #7
Crawl underneath and look for a tank drain. Should be a small valve hanging out somewhere in the area of the tank.
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
Old 10-14-2016, 02:04 PM   #8
A lot of tanks have a drain fitting under the trailer, usually just a pvc type fitting with a cap you can unscrew to drain. I changed mine to a small valve which I open as I leave the campground. Doesn't take long to completely empty the tank.
BIRDS AREN’T REAL
Old 10-14-2016, 02:37 PM   #9
Citrus County, Fl.
GL1800Rider's Avatar
2016 Jeep Wrangler
Dana Point, CA
I have a Forester so this should be the same valve as you. Inside the passenger side compartment where the air bag fill is you will see another compartment door. Blue hose with the green valve. Open it and the fresh water tank will drain very slowly. If anybody is curious about the black wire at the bottom of the picture it is my water alarm purchased for about $10 at Lowes.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 10-14-2016, 09:41 PM   #10
Low water drains are co-located with the field mouse entrance (see emm's picture).
Skyliner is offline   Reply With Quote
