Old 09-08-2016, 11:57 AM   #11
wmtire's Avatar
You have an Atwood water heater. There are several good youtube videos on how to clean the burner tubes on these.
2011 Flagstaff 831 RLBSS
Hypochondria is the only illness I don't have.
Old 09-08-2016, 12:03 PM   #12
raytwntrvlr's Avatar
Well, if I had dropped around 100K on a nice unit like yours, I would probably head back to the dealer... you should not have to take stuff apart and clean it already. Yours is not that common a problem and it could be something you can not repair yourself.
BTW.... Sometimes DIY attempts at repairs can muck up warranties.
2015 Flagstaff Super V 26VFKSS Emerald
2013 RAM 2500 CC 4X4 6.7 CTD
Sold... 2013 Shadow Cruiser 260BH
raytwntrvlr is offline   Reply With Quote
Old 09-08-2016, 12:07 PM   #13
DAISY BOYKIN's Avatar
Bug or spider
There may be a bug or spider in the curved tube where the propane and air are mixed for proper combustion. It only takes a small bug or spider to screw up the oxygen (air) mixture in the mixture tube to cause the bright yellow flame.
I would recheck the mixture tube again for a obstruction.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
BOLIY PRO 3600SI GEN
DAYS CAMPED 2016 74 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 09-08-2016, 12:19 PM   #14
Head Rambler
One problem is that if it is a bug or dirt, that's not covered under warranty, no matter how new it is. The dealer may well fix it for free, but if they're at a campground/resort it would require them to break camp and drive to the dealer. Removing and cleaning the burner tube is a few minute job. And it's more common than you think for bugs to invade propane appliances. For some reason they love the stuff.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 09-08-2016, 06:01 PM   #15
DouglasReid's Avatar
Originally Posted by Bama Rambler View Post
Good photo. I think you need to pull the burner tube and clean it out. A spider web or mud dauber nest in the burner tube will cause exactly the problem you saw.
You may want to remove the orifice and clean it as well while you're there.
X2, you have an obstruction somewhere, beginning at the burner orifice and ending at the exhaust. Find it, clear it, and your problem will be solved.
Maurice, LA
2012 Wildcat Sterling 32RL
2008 Chevy Silverado 2500HD LT Diesel
TST TPMS system w/ Flow-thru sensors
2001 Cougar 281 EFS (sold)
DouglasReid is offline   Reply With Quote
Old 09-10-2016, 10:59 AM   #16
Originally Posted by 13STL View Post
Here is the photo...
Nice picture. Just a thought, but was wondering if this heater has ever worked?
All the cleaning advice is likely appropriate ASSUMING THE UNIT WAS FUNCTIONING ORIGUNAKLY. IF THIS UNIT IS BRAND NEW and has never been run on gas, the problem might involve other defects or installation caused defects. If it has never worked may truly be a dealer or factory issue.
Please post your eventual out come.
Tom48 is offline   Reply With Quote
Old 09-10-2016, 11:20 AM   #17
X2
Old 09-13-2016, 01:51 AM   #18
benagi's Avatar
Side question. Is there way to regulate the temperature on the Atwood hot water heaters? Ours is a little hotter than we like it.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 09-13-2016, 01:47 PM   #19
Head Rambler
Turn on more cold water!
Seriously, It doesn't appear to have an adjustable thermostat. However, you can buy thermostats with different temp settings and also adjustable units.
Gotta go campin!
Old 09-14-2016, 01:32 AM   #20
benagi's Avatar
Just thought I would check with the forum before looking for an adjustment. Thx for the reply.
1968 tent trailer
1985 Jamboree 23 ft
heater, hot water, propane, water, water heater
