Old 09-08-2016, 06:44 AM   #1
Problem running hot water heater off propane
Anyone experience problems with running the hot water heater off of propane? When my DH turned the hot water heater on with propane, the flame was bright yellow and it blew black soot onto the side of our motorhome. It almost seems that it burned it into the siding. I can't get the soot off. Any suggestions? The dealer told us to look to see if there were any cobwebs and also to try to adjust the slide to get a blue flame. No luck...
13STL
2017 Forester 3051S
Jill, Mark (and dogs Paco & Isabel)
13STL is offline   Reply With Quote
Old 09-08-2016, 07:09 AM   #2
nomad297's Avatar
It sounds like the exhaust may be obstructed. Is the soot coming from the exhaust or from inside of the water heater cover?
Bruce
nomad297 is online now   Reply With Quote
Old 09-08-2016, 07:18 AM   #3
It is coming from the exhaust. He checked for any obstructions, but could not find anything.
13STL
2017 Forester 3051S
Old 09-08-2016, 07:39 AM   #4
nomad297's Avatar
Then you probably have something obstructing the amount of oxygen feeding your burner.
Bruce
Old 09-08-2016, 07:46 AM   #5
Flybob's Avatar
Maybe a silly question, but did he light the correct place. It is possible to light the flame directly after the jet, ( the air mixture control ) before the air is mixed in on some models.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 09-08-2016, 07:59 AM   #6
This unit has an electronic ignition.
13STL
2017 Forester 3051S
Old 09-08-2016, 08:04 AM   #7
Head Rambler
Can you post a picture of the unit and a close-up of the burner assembly?
What all have you tried to get the soot off the siding?
You can try some Clorox Cleanup or Tilex on a rag to see if that'll get it off.
Also, Magic Erasers work well, but be careful with them as they're micro abrasive, so don't over do it.
Gotta go campin!
Old 09-08-2016, 08:16 AM   #8
Awesome cleaner! Removes soot! Fuel/Air ratio is off or spider web causing soot! Youroo!!
Old 09-08-2016, 09:59 AM   #9
Here is the photo...
13STL
2017 Forester 3051S
Old 09-08-2016, 10:50 AM   #10
Head Rambler
Good photo. I think you need to pull the burner tube and clean it out. A spider web or mud dauber nest in the burner tube will cause exactly the problem you saw.
You may want to remove the orifice and clean it as well while you're there.
Gotta go campin!
heater, hot water, propane, water, water heater
