01-09-2015, 05:25 PM
Procedures for Slide Out and Levelers
Is everyone in agreement that the levelers should be lowered before the slide(s) are extended? Also, we were told by our dealer that the unit should be either plugged in or generator running before lowering jacks or extending slide(s). In February's edition of Motorhome Magazine, an article in the P.O. Box states the engine should be running versus pedestal or generator.
01-09-2015, 05:36 PM
Retired
I'm in the habit of jacks down before slides with the trailer plugged in if possible.
ON EDIT: I see now you're referring to a MH but I think the same applies for both.
2014 Chevrolet Silverado 3500 LTZ CCLB DRW D/A - Rancher Grille Guard - Transfer flow 40 gallon Toolbox/Tank Combo - Line X - Edge Insight
2015 Palomino Sabre 33CKTS - Platinum Edition - Progressive Industries EMS HW50C - JT Strong Arm Stabilizers - Ground Control 3.0 - 320 Watt Solar with 2000 Watt Inverter
01-09-2015, 05:49 PM
I'm just the opposite. I open all sides then extend the rear stabilizers. I don't want the frame torqued one way or another then have to run the slides out. Just my .02
01-10-2015, 08:32 PM
I was told to level with jacks while engine is running 1st thing you do when you ready to set up but this was back in 2003 when bought my 1st mh also theirs a lot of difference in leveling jacks and Stabalizers I put the slides out first when I used stablizers on other rv's
01-10-2015, 08:42 PM
For mine, same as most, I lower the jacks (auto level) first then the slides. Slides are too heavy without stabilization.
Mike & Sharon
Furever Coaching -lots of foster dogs
2014 Pathfinder Elite 404rb
2012 Ford F150 4x4 Lariat, Ecoboost
2009 Harley Davidson Road King
01-10-2015, 08:54 PM
On my 3051s I level with auto levers first then pull slide out, I don't want that full wall slide bouncing around as it hangs out there, as the auto level does its thing. Also I feel if your battery is fully charged why do you need engine running to level unit?
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
01-11-2015, 03:23 PM
Do the same with ours. Don't understand running the engine to level either. Out of curiosity, did you have many quality problems with your 3051S?
01-11-2015, 03:56 PM
Our Forester has the Bigfoot automatic levelers and the manual states the MH should be plugged into 110-v. or generator running during leveler and slideout operation. Reason being to ensure the battery maintains proper voltage during operation. The ignition key should be in the off position.
01-12-2015, 09:56 AM
Commercial Member
Correct. For the levelers to work properly the unit should be leveled FIRST, then the slides out.
If not, the unit will get level, but could end up higher than need be. If the unit leans due to the slide, it could set the level off the high side first, which brings the low side up, instead of the high side down.
04-06-2015, 08:37 AM
i have the pathfinder elite 404rb, 4 slides, 3 of the slides work perfectly..one will not budge. Are there separate motors for each slide where i could manually retract the slide? It is stuck extended so i can't take it anywhere till i get it retracted. we have had the unit only about 6 months, no trouble till now. My usual procedure is to plug into shore power (at least 110v), shut off engine, lower jacks, then extend slides. Worked fine up till this last weekend when we were headed out. Fortunatley it stuck at home so not on the road. Operator manual is no help for manual operation (if that's even possible). Help? And thanks.
Mike & Sharon
04-06-2015, 09:08 AM
Commercial Member
Just a heads up. You are on a Motorhome sub forum. While you will still get responses, you may not get as many or ones specific to your brand.
04-06-2015, 09:32 AM
Think about it for a second.
You want to extend the slides without having them bind due to a twisted frame.
First you level the unit with generator or shore power on because there is no need to strain the batteries when power is available.
Then you extend the slides now that the frame is all perfectly level and untwisted from the uneven site you probably parked on.
If you need to tweak it a little now that the slides are extended you can do that now.
Not sure why you would do it any other way.
04-06-2015, 05:46 PM
We are new to the automatic leveling. Do you have to block the wheels before leveling. Some of our camping has a down hill slope. We are ordering the 3171DS. Thx for any help in this matter. Ben
04-13-2015, 09:06 PM
I always chock the wheels. If your rear wheels come off the ground, the parking brake will be useless. I find auto mode is too aggressive. I now level in manual mode.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
04-13-2015, 11:34 PM
Garrette, thx for the info. Nice 3170, how's she holding up?
04-14-2015, 07:52 AM
If we see that any of our wheels will be off the ground, we use leveling blocks beneath them.
04-14-2015, 08:13 AM
On my 3170 I use boards to get at least 1/2 to 3/4 bubble from level before running the jacks then push the auto level. I have never raised a wheel off the ground doing that . Then I run the slides out.
04-14-2015, 08:12 PM
She just turned 2 and could Not be happier. Well, more camping would make us happier. After 8000 miles, no issues after the typical stuff was repaired. Generator fuel pump, awning motor recall, alignment. Seems the more we use it, the better it gets.
04-15-2015, 07:02 AM
Coach-Net
If it is only 6 months old call Coach-Net they can assist with Tech service or getting a mobile mechanic authorized to repair it.
2015 Siera 377FLIK
2014 Ford F350 KR
Maggie the new Chihuahua
Cricket the Chihuahua RIP
Steve & Jojo
