Originally Posted by CedarCreekWoody
If you have hook ups an electric space heater can lighten the load on the propane heater.
I hope the foliage is in full color for you thete!
We re-fill our tanks about once a year by using a space heater. We only use propane for hot water and cooking. Typically we will turn on the heat when we arrive to get the camper up to the desired temp. Then we switch over to our space heater, that will run us out of the camper even on the coldest of days. We are in a 30 amp unit, so we do have to be careful with using the microwave at the same time. Just switch off the space heater real quick.
I am a big fan of the Vornado series of space heaters.
