Old 12-12-2016, 11:01 AM   #1
Propane furnace won't lite off
Nothing but cold air coming out, fuses good, hear the click at the igniter but won't start up. Exhaust tubes seem clear, but can only see a portion of it. Any help before I bring it to the mechanic, I'm leaving on a trip to new Hampshire in a week, no heat cancels my plans.
Thanks in advance
Jdarryld is offline   Reply With Quote
Old 12-12-2016, 11:04 AM   #2
Do any of the other propane appliances work?
Stove, water heater, etc.
Days Camped: '17=30 '18=51 '19=58 '20=21
Old 12-12-2016, 11:05 AM   #3
Ford Idaho's Avatar
Tank/s full and turned on?
Does a stove burner light?
Old 12-12-2016, 11:10 AM   #4
Yes, stove lites, fridge works. I cycled through and purged the system 3times the propane tank 3/4 filled at this time.
Old 12-12-2016, 11:12 AM   #5
I have it winterized now so can't check water heater but it was working fine. Never tried the heat recently purchased from friend he said was working fine the week before I bought it. Last time he lit it off. I'm long time camper, so this has me baffled
Old 12-12-2016, 01:01 PM   #6
I had the same problem and the furnace started magically working on it's own at a later date.
Furnace not working
newRVer is offline   Reply With Quote
Old 12-12-2016, 01:24 PM   #7
herbike's Avatar
Had that trouble with older Suburban furnace. Turned out to be bugs on the igniter. So before we left each trip I would take the air hose and blow in the exhaust port and never had that problem again.
Days camped in 15-180 days-16-95 days
17--114 days-18-71-days
19-32
2016 t28FQDX Shockwave, New Provider tires 10/31/18 ,TV-2015 LTZ Duramax with over 156,000 miles, with delete done, 2014 Polaris RZR 800 EPS/ 11,700 miles
herbike is offline   Reply With Quote
Old 12-12-2016, 01:26 PM   #8
Old Enough to Know Better
gasman6674's Avatar
Did you power cycle the furnace by turning the tstat to off? If the furnace has never been fired it takes a while to bleed the air through the pilot burner as it is a really small hole.
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
Coming Soon: 2020 Keystone Cougar 364BHL
gasman6674 is offline   Reply With Quote
Old 12-12-2016, 04:13 PM   #9
djemgoss's Avatar
propane furnace won't lite
I had a similar problem with our brand new Roo 21SS. It was working just fine and then stopped working and would not lite. I hear the fan start up and the furnace clicking try to lite and then shut down. Looked at the fuses, propane tanks and all were good. Took it to the dealer the next morning and they looked at it right away and determined that the furnace "high limit switch" had failed. They had a new part and put it in and have not had a problem again!
Dave & Elaine
Brookfield, WI
2016 Rockwood, ROO 21SS, pulled by a 2015 F150 XT, Super Cab, 2.7L Eco Boost, with 3.55 axle. Electric 6-speed auto trans w/tow mod. Tow package & integrated trailer brake. 7,600 lb. tow capacity. 145” wheel base. Equalizer 4 point W/D hitch.
djemgoss is offline   Reply With Quote
Old 12-12-2016, 04:24 PM   #10
cphubert's Avatar
I had small black spiders build a web/egg case that stopped the LP @ the burner had to clean it. Boy they drove me crazy all the other appliances worked and the furnace ran thru its cycle but would not light.
cphubert is offline   Reply With Quote
Old 12-12-2016, 07:23 PM   #11
Thanks everyone, I suspect it is a clogged burner tube. Due to work travel tomorrow i dropped it off at my RV mechanics shop. I will let everyone know what the culprit is.
Thanks again
JD
Old 12-15-2016, 01:00 PM   #12
Hello all, I got the RV back from the mechanic, it was clogged burner tube. Dirt Daubers got in and made nests as suspected.
I will be closing off the vents when not in use. I couldn't clean it out without removing the unit. Had no time to mess with it. Thanks for all your replies.
Old 12-15-2016, 04:27 PM   #13
Ford Idaho's Avatar
Glad you have it working now and thank you for posting back with the cause and fix.
Old 12-15-2016, 05:14 PM   #14
No problem I know how frustrating not getting closure to an issue is.
Regards
JD
Old 12-15-2016, 05:35 PM   #15
Left Coast
Put screens on...
furnace, propane
