Old 07-05-2019, 07:56 PM   #1
Campincarters's Avatar
Propane regulator 3011DS
Hello the propane regulator on my 3011ds is hissing from the weep hole. Can I replace it with a similar regulator or do I need the exact same one.
Thank you for any help/advice. I posted same question in the propane thread but hoping for more people to see it.
ID:	209076   Click image for larger version
ID:	209077   Click image for larger version
Campincarters is offline   Reply With Quote
Old 07-05-2019, 08:26 PM   #2
Once you get the regulator off you should be able to find the manufacturer name and model number. Once you get that info I bet you’ll find an exact replacement on Amazonor Walmart.
BIRDS AREN’T REAL
Old 07-05-2019, 08:40 PM   #3
Any two stage regulator will work. Many are rater for vertical or horizontal mounting. You need horizontal, the only difference between them is the position of the vent.
On the one you have you will see the vent is pointing down, that is the correct orientation. You most likely will either need to reuse the POL fitting to the tank or purchase one separately.
FYI the POL fitting that goes on to the tank valve is a left hand thread.
2021 Newmar Baystar 3401
2019 Jeep Cherokee Trailhawk toad
2017.5 Forester 3051S Traded 7/2020
Steve-W is offline   Reply With Quote
Old 07-05-2019, 08:46 PM   #4
Thank you look like I have a mb sturgis 2 stage horizontal. Hopefully the rv store near me will have a similar one.
2017 Forester 3011DS
Old 07-05-2019, 08:51 PM   #5
eTrailer has it for about $35. Good outfit to deal with.
BIRDS AREN’T REAL
forester, propane
