Old 06-16-2018, 09:38 AM   #1
Questions: adding air to ride rite airbags
I have a 2018 forester 2861 DFS, and am having a problem adding air to the air bags. The ends of the valves are located in a storage bay on each side of the coach, but there is so little of the valve extended that I canít get the air hose in enough to apply pressure to the valve. Has anyone else run into this issue? Any ideas would be appreciated. Currently, there is only about 15 pounds of pressure in the bags.
cstrunk5040 is offline   Reply With Quote
Old 06-16-2018, 10:22 AM   #2
Tombsy's Avatar
Mine was a real PITA as well, I had to remove the nut to fill or check them and hold the stem so it didnít push thru. There must be an extender that will fit to make it easier.
But one of the best things Iíve done on my rig was to install an Airlift Wireless One on board compressor for the airbags. It has a wireless remote that you set the pressure with and then forget it. It comes on once in awhile and keeps the pressure where you have it set. Itís a really small enclosed compressor that I put at the end of a storage compartment.
I installed it myself but the wiring was a little tricky, I wired it to the coach batteries and I added a second relay and a switch to turn it off when parked.
Brian
2015 Forester 2801QS GTS
TOAD-Hobie Mirage Pro Angler 14 kayak and Yamaha Zuma 50cc scooter on a custom trailer.
Tombsy is online now   Reply With Quote
Old 06-16-2018, 11:51 AM   #3
Sagecoachdriver's Avatar
Tombsy, is that the entire compressor? Looks small. I see the Airlift Wireless one listed for $300, is that right?
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
Sagecoachdriver is offline   Reply With Quote
Old 06-16-2018, 12:11 PM   #4
Duckogram's Avatar
I had the same problem but took the el cheapo route. I took the nut off the front and pulled the valve out. Then I removed the rear nut that was restricting the available length of the stem. Slopped a bit of silicone around the base and stuck it back in. Replaced the thin washer and nut and it worked just fine. But I did not like the schrader tool valve cap on there so I replaced them with Alligator caps. YMMV
ILB ( | )
Old 06-16-2018, 01:05 PM   #5
Thanks for the suggestions! The wireless ac looks like a nice option for the future. I found some short brass extenders at autozone. Iím going to try that first. Getting at the back of the valve is somewhat problematic in my installation. It is in a tiny space between the wet bay and the back storage bay.
Old 06-16-2018, 03:29 PM   #6
lakewood90's Avatar
X2 on the valve extenders. A cheap and easy fix that worked for me on the Sunseeker. I normally ran my 3010 at 70 psi, which worked for me with our normal load. We did not have a problem with leaks and always checked them before a trip in the morning when it was cool, just as you would with checking tire pressures.
Tiffin Allegro Bus 43QRP DP
(Sold)2016 Sunseeker 3010DS
TOADs: Honda CRV and Jeep Grand Cherokee Overland 4 x 4
lakewood90 is offline   Reply With Quote
Old 06-16-2018, 05:26 PM   #7
Tombsy's Avatar
Yes that's the one the Air Lift 25870 WirelessONE Compressor System. The compressor is pretty small, it's in the black metal box, the airbags are pretty small as well so it doesn't take much air. I mounted the compressor, manifold, and relay on the black board in the picture.
Brian
Old 06-17-2018, 09:26 AM   #8
JimOneil43's Avatar
AirLift 72000?
Has anyone installed the AIR LIFT 72000 Wireless Compressor System? That is the one I have been considering, but it seems to be about $100 more than this one. It looks like the difference is in the compressor. The 72000 looks like a more traditional heavier compressor. Has anyone compared the two?
Retired and loving it...Can't wait to get back on the road!
2017 Forester 3051S ("Farley")
Born April 18, 2016
Toad: 2014 Honda CR-V AWD
GO DUCKS !!
Jim & Diana (and 3 cats)
JimOneil43 is offline   Reply With Quote
Old 06-17-2018, 09:28 AM   #9
Wolverine 1945's Avatar
If you are not able to reach the nut on the outside,,, extensions maybe a good try ???
Make sure they do not leak !!!
Wolverine 1945 is offline   Reply With Quote
Old 06-17-2018, 09:51 AM   #10
Tombsy's Avatar
One difference is you can set separate pressures for each side, on mine they are connected together.
One note, I left my original fill valves in place so I needed 2 extra tees for the airlines.
Brian
Old 06-17-2018, 11:46 AM   #11
Update: I was able to fix this issue by eliminating the washer.
Old 06-18-2018, 08:38 AM   #12
So just to make sure the Air Lift 25870 WirelessONE Compressor System will work with the Firestone Air-Ride air bags on our Foresters with no issues or modifications, correct?
It would be nice to be able to raise the rear end when I have to pull out of a driveway and thus prevent having to use the rollers I added on the hitch frame.
Old 06-18-2018, 08:41 AM   #13
I did the same thing, sans the silicone.
2020 Rockwood Mini Lite 2509s
2019 F-150 3.5 EB SCREW Max Tow - 1797 payload
Blue Ox SwayPro w/ 1000 lb bars
s1njin is offline   Reply With Quote
Old 06-18-2018, 09:28 AM   #14
Tombsy's Avatar
If you leave the existing fill valves in place you will need two additional airline ďteesĒ to tap into each side. I found it a lot easier than trying to access the top of the airbags. The kit comes with a relay to tap into an ignition source, I opted to tie into the chassis batteries so I added another relay to a switch. The existing airlines are in cable loom so I used it for the new ones as well.
ID:	176348Click image for larger version
Brian
Old 06-18-2018, 12:43 PM   #15
I have a very low tech no expense solution. I take the quick fill valve off the front tire, screw it onto the airbag valve and presto an extension! Works no problem every time.
Dino61 is offline   Reply With Quote
Old 06-18-2018, 12:56 PM   #16
Got $250 in Amazon gift cards from family for Father's Day. They're burning a hole in my pocket. Really thinking about buying the Air Lift 25870 WirelessONE Compressor System. Just not sure I want to do all the work installing it.
Old 06-18-2018, 02:29 PM   #17
Duckogram's Avatar
If that quick fill valve looks like this, itís the alligator cap I mentioned in post #4.
I have TPMS transmitters so no caps on any of my tire valve stems. The oemís were repurposed.
ILB ( | )
Old 06-18-2018, 11:35 PM   #18
Kirk S's Avatar
X2
Kirk
2017 Forester 3051S
Kirk S is offline   Reply With Quote
Old 06-20-2018, 12:07 PM   #19
Tombsy's Avatar
I have the Vair RV compressor, I have trouble with the quick fill caps, not sure why but the only chuck that seems to work for me is the screw-on one and its kind of a pain. Anyone else have the Vair and found a good chuck for it?
Brian
Old 06-20-2018, 01:01 PM   #20
Much easier without Hub Capos !!!
airbags, forester
