Old 01-22-2019, 10:22 AM   #1
rattle when accelerating
I have a 2018 3011ds Forester. Recently I have been hearing a rattling noise while accelerating. When I let up on the gas it stops. It doesn't seam to affect the performance of the engine. Any thoughts.
lacrawgator is online now   Reply With Quote
Old 01-22-2019, 10:26 AM   #2
A32Deuce's Avatar
I have one at certain RPM a resonance vibrates one of the exhaust heat shields. You can tap them and maybe hear it, but I haven't found it yet.
A32Deuce is offline   Reply With Quote
Old 01-22-2019, 10:35 AM   #3
Usually Confused Member
emm-dee's Avatar
I had the same issue. Went to local Ford dealer who said it was fan belt. I didn’t see any way that could happen but, sure nuff, when they replaced the belt under warranty all the noise went away. FWIW, mine made lotsa noise when cold but when at normal temperature it only did it at 2,000-2,150 RPM.
A quick check you can do at home is to remove the belt and start the engine. It’s easy to remove and, obviously only run it a very short time.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 01-29-2019, 03:02 AM   #4
Kirk S's Avatar
I'm assuming the engine is a Ford V-10?
It may be predetonation (spark knock). Try some mid-grade fuel and see if it goes away if the previous suggestions dont work.
If you get it resolved please let us know how.
Kirk
2017 Forester 3051S
Kirk S is offline   Reply With Quote
Old 01-29-2019, 07:58 AM   #5
emm-dee's Avatar
That was my initial thought when my V10 started making the noise. I used to have Corvettes before the age of electronic ignition controls so I definitely knew the sound of predetonation.
Ran the fuel down really low and then filled the tank with premium fuel. No change so tried a few different additives with no success. When the shop manager told me the fan belt was the problem I looked at him like one would look at someone who just told you the earth is really flat.
Apparently thereís a problem with the fan belt being out of balance. This causes it to generate a vibration the makes the heat shield rattle. Sounds logical because a cold engine makes more noise. As the fan belt heats up it stretches and generates less vibration.
Old 01-29-2019, 01:21 PM   #6
AquaMan's Avatar
Some heat shields will break a weld at the mounts and cause a rattling, and banging on them may not produce any sound. Had this happen on a Jeep.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 01-29-2019, 01:30 PM   #7
Who Dares, Wins
doc73's Avatar
Had a few timing chain issues on my Fords as well. Causes a rattle under acceleration.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
