Old 01-26-2015, 01:19 PM   #1
DnL
RCA (TV) splitter box location
Does anyone know where I might find the RCA (TV) splitter box in a 2013 Forester 3011DS? Two of our three TVs started showing DVDs in black and white, so I’m thinking there is a loose wire somewhere – maybe at the splitter box.
I have a Magnadyne entertainment center in the dash with a Magnadyne VCS-10 switching center mounted inside the cabinetry under the main TV. All of the wires from the switching center go into the cabinetry behind the main TV. Would the splitter box most likely be back there (behind the main TV); or somewhere between the main TV and the rear compartment (bedroom); or under the cab dash?
Thanks in advance for your help.
DnL is offline   Reply With Quote
Old 01-26-2015, 02:26 PM   #2
Scubanut's Avatar
On my unit which has 3 tvs the splitter is behind the main tv in the kitchen.
Scubanut is offline   Reply With Quote
Old 01-26-2015, 05:48 PM   #3
DnL
Thanks Scubanut.
So now I'm wondering - do you know - if I get the main TV down from its mount (not a swivel one) will there easy access to what's behind it - like a hole in the bulkhead?
Old 01-26-2015, 07:08 PM   #4
Scubanut's Avatar
In my case I have a swivel tv mount that goes between the bedroom and kitchen living area. I just pulled off the back panelling 6 screws and had access to the splitter there.
Old 01-26-2015, 07:09 PM   #5
Scubanut's Avatar
I have the coachman freedom express 292bhdd
cat, location
