Old 04-23-2019, 08:25 AM   #1
Sagecoachdriver's Avatar
Re-wire Winegard plate for Satellite to Bedroom TV
My 2016 Forester's bedroom TV only has OTA reception and internal DVD player. I would like to disable the OTA and place a splitter in-line after the Dish Satellite receiver so that the bedroom TV can get the same channel as the upfront main cabover TV. Below is a photo of the 2 plates by the up front TV and a diagram of the amplifier panel. I thought maybe disconnecting the Set 2 cable and attaching a coupler and cable going to a splitter off the cable running from the Dish receiver to the upfront main TV. Then I could I add another splitter just before the Set 2 cable in the diagram with one going to the switch panel and the other going to the splitter off the back of the Sat receiver thus giving me both OTA and SDat reception? Will this work and has anyone done this mod?
Just a note, tthe black cable on the amp white plate is the cable coming off the roof satellite and goes to the sat receiver.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
Sagecoachdriver is offline   Reply With Quote
Old 04-23-2019, 11:33 AM   #2
Just realized that it would be going from HDMI from sat receiver to coax,, is there an adapter?
Old 04-23-2019, 06:42 PM   #3
Dcbenny's Avatar
I added an HDMI splitter and ran a HDMI cable to rear TV and one to an outside TV works great
Don & Liz B.
Pink Retired Greyhound
2016 GTS 2800QSF
Dcbenny is offline   Reply With Quote
Old 04-23-2019, 09:09 PM   #4
i have run an HDMI cable to the outdoor TV and just switch cables at eh receiver when needed. Thought I could somehow do it with the rear TV. How did you route it?
Old 04-23-2019, 10:42 PM   #5
Thanks, I was able to follow the coax in the bedroom down the wall and could see it when I removed the hatch in the shower below the knobs. traced it down under the shower pan to the wall and along the back side of the toilet to under the sink, closet drawer and under the fridge. Will try some more tomorrow. Mine probably runs from under the fridge up the side and passing into the compartment cut-out for the convenience panel with a thousand wire. Then it's going to get tricky the last 7 feet with the dinette slide out in the way and into a post above just in back of the driver's seat along the cabover bunk wall. Rough easurement was 30-35feet, so I will order 50feet of HDMI and a splitter.
Old 04-24-2019, 06:17 AM   #6
Dcbenny's Avatar
I have a different model and needed to use a short piece of wire mold on the ceiling to get across the door way. Looked at your floor plan can you drop it into the outside compartment under the side. The coax may also be under your dinette seating area with extra wiring to allow for the slide out to move. Enjoy the project
Don & Liz B.
2016 GTS 2800QSF
Old 04-24-2019, 07:57 AM   #7
Thanks for the info. Can't be any harder than routing the solar cable down the fridge vent into the void alongside the fridge and under the fridge, cabinets, same raised flooring. Just a lot of time on my belly. I'm going to post photos of the possible route later today for suggestions. I could run it under the dinette as you mentioned then just attach it to the wall just behind the driver's seat as no one will see it because of the slide . Ordered 40 feet of HDMI and a triple splitter and should arrive tomorrow Amazon Prime.
Old 04-24-2019, 11:22 AM   #8
Here's photos of the possible route. So again, down the wall and under the shower pan. Then along back of toilet to under vanity sink and closet/cabinets and refrigerator. Then I have options of going up the side of the fridge and come out thru wall at height of top of dinette slide and running it along the top of the seals to the post holding all the TV wiring. Or, I could come out of the wall at floor level in the back and run it under the slide-out going up the wall to the TV post. Any thoughts? I'm thinking going along top of slide-out rather than under it.
ID:	202696   Click image for larger version
ID:	202697   Click image for larger version
ID:	202698   Click image for larger version
ID:	202699   Click image for larger version
ID:	202701   Click image for larger version
ID:	202702   Click image for larger version
ID:	202703   Click image for larger version
Old 04-24-2019, 02:16 PM   #9
joel ritchie's Avatar
Cable run
The little u that’s there at the ant amp is we’re I hooked up my sat dish out put with a cable coming off the back of the sat receiver. Now under the sink and the little pantry is were I found a splitter that was wired wrong. They hooked up a out to a in on the splitter. Now you will have to put the tv in the back on ch 3 or 4 I have something I will send you .see if this helps . I have a 2015 3011ds
Name:	2018_12_18 15-27-44.jpg
ID:	202715   Click image for larger version
Name:	2018_12_18 15-28-41.jpg
joel ritchie is offline   Reply With Quote
Old 04-24-2019, 06:03 PM   #10
I ran a string down the wall and under the shower pan. Couldn't get past the back of the toilet. Tried from both sides. Was able to remove the shower J trap cover and had good access under the shower, but there was only a slit next to the wall for a 110 romex to go thru. I tried that but again couldn't get past the back of the toilet. May have to drill a 3" hole and see what the issue is. I placed a flash light under the shower pan at the slit opening and could barely make out the light from under the sink vanity. I removed the bottom of the vanity for access but it's a real tangled mess of wires and pipes as the vent is also there in the wall.
bed, lite, roo, satellite, winegard
