Old 06-29-2016, 11:15 PM   #101
Sagecoachdriver's Avatar
Ready to install, but too HOT!
First I will work on the roof top cable entry down the fridge shaft.
Went to Home Depot and bought one of the stress relief connectors and lock nut. I know there are many types, some metal and some plastic. This one may require a dab of Dicor on the cables when done, will see. Going to drill a 3/4" hole on upper side of base allowing for cable clearance and on opposite end from flue. Devised a crazy way to attach the lock nut. I tested it simulating the side of the base. Very involved and can take 5 minutes or an hour.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 2 trips 5 nights
Sagecoachdriver is online now   Reply With Quote
Old 06-30-2016, 07:44 PM   #102
Received my StickyFeet, awfully small???
I was surprised when I opened the box and saw how small they actually are. Just 1"x3" of 3M VHB tape. For some reason I thought they had a much larger base. Not sure what I'm going to do now. Spent a ridiculous $18 on shipping. Going to have to give this some thought??????
Old 07-02-2016, 12:48 PM   #103
That's probably more area than the ones I used on my little mounts.
I should write up my install. Some day I will. I learned a few things not to do. None of which are germane to your plans today.
I know it feels like each of us is inventing the wheel. It's too bad it's like that.
2014 Sunseeker 2300 Chevy
Snowman9000 is offline   Reply With Quote
Old 07-02-2016, 02:04 PM   #104
Rich.M's Avatar
Just use the sticky feet on the lightly sanded fiberglass roof and allow to set. Then go over with the adhesive cauck. Allow that to set. Then over with Dicor. The mounts will be solid and when you pull on them you will have no concerns. Screws not needed. We have been driving thru the plains , colorado and utah this week at 75 mph without any problems.
Rich.M is offline   Reply With Quote
Old 07-02-2016, 08:02 PM   #105
Busy day running cable
I decided after installing the stress relief connector on the side of the base, I would pull the Convenience Panel above the fridge. Sure enough, there was a double walled panel backing up to the fridge vent. I drilled a pilot hole and then a hole large enough for the cable. You can see it in the photos. Now the cable is just a short loop instead of running all the way down to vent shaft. I then routed the cable down where the grey arrow is in the void alongside the fridge. Next it was easy to fish it under the cabinets to where the raised floor is. I had previously fished a line under the floor. I started to pull the cable thru and pulled off my cord. Then spent the next 2 hours fishing it thru again. It was an easy route under the oven and sink to the trash cabinet where I will mount the controller only a few feet to the batteries in the step well.
I did finish up the day caulking all the holes even the double wall one turned out good. Sealed looking into the vent shaft and the inside void behind the Convenience panel.
Still waiting for the fuse/cutoff to arrive and I need to get sone 8 awg wire for the controller to the batteries. Going to take HopHed's advice and move them around for a few days checking out the charging and looking for shadows.
Will probably mount the controller and attach the feet to the panels. Any suggestions on how close to the corners they should be?
ID:	112876   Click image for larger version
Old 07-06-2016, 04:48 PM   #106
Solar Update
finished the wiring and have mounted the Controller along with my Xantrex Battery Monitor, Cutoff switch for panels to controller and a 30 amp fused cutoff for controller to batteries. It's in the trash basket cabinet by the step well.
Second photo are the 2x100 watt Renogy panels with StickyFeet attached and sitting on wood. All connected and working fine. Will move them around in the next day or so and see where I want to install them.
I'm going for overkill and sanding down the dimples like HopHed did and drilling 2 holes in each foot base. I'm going to use 2 hollow wall anchors for each foot along with the 3M VHB tape and adhesive caulk. Reason is we travel up the Grapevine here in SoCal and it gets very windy. We can have 40-60mph gusts and driving into that will put the panels at risk. Peace of mind!
In looking at the roof photo, do you think it would be better with the panels closer together so the Air Cond blocks some of the wind?
ID:	113276   Click image for larger version
Old 07-07-2016, 12:21 AM   #107
Anyone following this anymore?
Old 07-07-2016, 12:23 AM   #108
benagi's Avatar
Yes, Sage. Good info. Read it every nite.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 07-07-2016, 01:32 AM   #109
Just you HopHed and me!
Moving along slowly.
Old 07-07-2016, 10:16 AM   #110
2007 WildCat 32QBBS
05CrewDually's Avatar
I'm here just taking it all in. I hope to have panels one day.
05CrewDually is online now   Reply With Quote
solar
