Old 07-07-2016, 11:37 AM   #111
flocktothewall's Avatar
Been following silently. Thanks for keeping an update. Thinking of putting the same size on my MBS rig also.
flocktothewall is offline   Reply With Quote
Old 07-07-2016, 12:26 PM   #112
HopHed's Avatar
Still here and following but on the road. I understand about the piece of mind putting screws in. We have gone over the grapevine, up to seattle and half way back down the coast and very confident the panels are not going any where without using screws. Good luck with final panel install. Looks good so far.
1978 Ford Rollalong
2004 Fleetwood Tioga 29V
2016 Forester 2861DS (11-13-15)
HopHed is offline   Reply With Quote
Old 07-07-2016, 01:06 PM   #113
2012 Solera
A couple years ago I installed a single 100 watt monocrystaline panel, a Renogy kit. I attached with eight Renogy mounts, SS screws, and Dicor. Has been perfect for 3+ years and probably 25K miles. Just inspected yesterday - no sign of any mount issues. I also ran the wire down the awning channel rather than the refrigerator vent. The single 100 watt panel has worked well to keep the batteries up while stored. Also notable help while boondocking (but doubt it would keep up for more than a few days). Does what I want. Of note, I did reduce the cutoff voltage from Renogy's default of 13.7 volts to 13.2 volts - reduced battery water usage in storage to negligible.
My earlier post on installation - post #14:
Solar system installed
Following your posts-
Regards, Jim
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 07-07-2016, 01:12 PM   #114
Sagecoachdriver's Avatar
Cancelled our trip to Idyllwild this weekend as our neighbors bailed on us and I would be thinking only about finishing the solar. HopHed, my StickyFeet came with nuts and bolts to fasten them to the panels. Also my panels had pre-drilled holes for the mounts. They were obviously made for the Renogy mounts as the StickyFeet are set back slightly.
I placed one panel on the roof for a few minutes while I cut up wood 2x4's to raise the panels. When I came back, the 3M VHB tape was gooey because of the warm roof. Hope I didn't ruin them! It was only one panel and only 4 mounts as I hadn't attached the center ones yet. I moved the tape back and as it cooled, it looked normal again. Dumb move on my part.
I think I know where I will mount these two panels and need to go to the hardware store for fine grit sandpaper and a few screws. Also, I need to get some adhesive caulk. Not sure if I should try CW or my dealer for that.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 0trips 0 nights
Sagecoachdriver is offline   Reply With Quote
Old 07-07-2016, 02:59 PM   #115
Sikaflex 505 UV adhesive sealant caulk, anyone use this one?
Old 07-07-2016, 06:21 PM   #116
I am watching and learning. We have a TT and have put the 6 volt batteries on, but trying to figure out how to run the wires. Your pictures really help.
XLR 24 HFS
Bpenn is offline   Reply With Quote
Old 07-07-2016, 09:28 PM   #117
MNtraveler's Avatar
Following. Not quite ready for this yet. Thanks for the info.
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 07-07-2016, 10:24 PM   #118
Received the inline fuse today that will go on the end of the positive Y connector on the roof. Now it has cutoffs and fuses from panels to the controller and controller to the batteries.
Will pickup some Sikaflex tomorrow from CW, mark where the feet are going to go and sand the dimples down a bit. Next, I need to drill the feet for the hollow wall anchors and hopefully Saturday or Sunday morning I can start permanently mounting the panels before it gets too hot.
Old 07-08-2016, 12:41 AM   #119
Please make sure those are NOT Windy Nation inline fuses. They are loose on the inside and make either a bad, intermittent, or no connection on the inside.
If they are Windy Nation fuses, remove the fuses and tape them so they dont' rattle and then put a spring on top of one fuse end so it ensures a good connection.
Skyliner is offline   Reply With Quote
Old 07-08-2016, 02:12 AM   #120
solar
