05-26-2016, 08:42 PM
#61
Originally Posted by Tom48
For all of you who want to force the flow over the top of the panel, REMEMBER that is how an airplane wing works to create lift. Maybe an obstruction to keep the branches from hooking under the panels or maybe a wedge shaped leading edge for the panels to reduce wind resistance but probably ought to think twice about the aerodynamic effect of directing the flow over the top only. Think bernoulli's principle before you do something that defeats your intention and SUCKS the panels off the roof.
Thanks. Thought about that and now will definitely NOT put any air deflector device in front of the panels.
1978 Ford Rollalong
2004 Fleetwood Tioga 29V
2016 Forester 2861DS (11-13-15)
05-26-2016, 10:31 PM
#62
Yes, thanks for the information about the air dam.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
2020 Camping 0 trips Cancellations 6
05-26-2016, 11:27 PM
#63
LOL I'm sure that you will do a great job. Heck I threw my first set of panels up there so randomly and hit the four feet with big old SS sheet metal screws and slopped dicor on their feet and THEY NEVER CAME OFF So with the planning and forethought that you put in to it yours will be great.
05-27-2016, 02:58 PM
#64
BEFUDDELED MEMBER
Just finished my 200w system yesterday
From AMAZON
2- 100w RENOGY panels
HQST 20a controller
MT5 remote meter
PV 17v@10a / 14.6v@ 12A to battery
roof pic's were taken before I tested system and had not secured the roof cables just in case.
I will be adding one more panel next month .
I used 6 Renogy pannel mounts with 2 screws each panel for extra security.
13,SUNSEEKER 3010
RETIRED / New Mexico
D KZ5PZ - EXTRA -DW K5ZPZ - GENERAL
Viet combat vet USNR, DAV, VFW, CCL. SASS
05-27-2016, 03:32 PM
#65
From AMAZON
HQST 20a controller
MT5 remote meter
Looks good.
Did you use any adhesive or VHB tape or just screws? Is that Dicor on top or adhesive?
The picture shows a shadow on the panel on the right. If so, that will dramatically effect the output with the shadow on it.
1978 Ford Rollalong
05-27-2016, 10:45 PM
#66
BEFUDDELED MEMBER
I used butyl rubber tape under mounts and dicore to make sure. Where ever you locate the panels they will have some shade in morning or afternoon from something, determined by rig orientation. Max panel output is during mid-day when sun is directly overhead and decreases as the suns angle increases.
13,SUNSEEKER 3010
05-28-2016, 04:10 PM
#67
Panel dimensions
Went on the roof and took measurements. I would like to get 200-300 watts total for now. The Renogy 100w are 47x21 and would fit. But 3 panels and lots of Sticky feet. Seems like the better option would be 2 Renogy 150w on sale this weekend for $205 39".5x29" could fit in 2 configurations. Any difference is rectangle vs square panels. I see that most of you with rectangle panels are using 6 mounts. With the square ones I would be more comfortable with 8 sticky feet. Wow, 16 times $12 is $192 for the mounts. Is that overkill?
05-28-2016, 04:24 PM
#68
From what I understand anything about 4' in length or more they recommend a mount in the middle of the long ends for support. The 47" on the 100w is borderline. Why not go with 2, 160 or 165w panels (60X29). I got 2 165w panels for $350 total including shipping. Shop around. On the square 150w panels you should be ok with 4 mounts on each. That would be 8 total not 16. Not sure how you figured on 16 mounts for those.
1978 Ford Rollalong
05-28-2016, 04:31 PM
#69
4 on the corners and 4 in the middle of each side. Your 160's are too large for my roof. They will get too close to the A/C, maybe not??
05-28-2016, 04:54 PM
#70
BEFUDDELED MEMBER
I would rather over engineer mounts than have a catastrophic failure.
JMHO
13,SUNSEEKER 3010
05-28-2016, 05:40 PM
#71
Here's the photo with dimensions. I thought this would keep the shadow from the A/C at a minimum and would partially block air flow while driving. Could put one behind the vent also and one in front instead. What I meant on the Sticky feet was 2 on each side as it's almost square equals 8 times 2 is 16. I suppose I could get by with 2 each on the slightly longer side and 1 each on the other sides.
05-29-2016, 01:16 PM
#72
If you scroll way back on this thread, you'll see Wolfwhistle's 150watt Renogy panels that I may get. I know 200 watts total at 11amps isn't going to recharge the house batteries after a 45-60 amp draw down daily. Definitely need 300 watts at 17+ amps. So either 3x100 watt or 2x150 watt. I like Renogy even if it's a few bucks more. Good customer service.
06-11-2016, 08:56 PM
#73
Almost ready to buy everything. Saved up Amazon gift cards.
HopHed, which panels did you buy again? I went on the roof today with a template and the Renogy 150 watt panels won't fit without getting too close to the A/c and have a shadow or too close to the vent and back of MH. Will have to either go with 3x100watt or 2x160watt from another brand. Renogy had the 150 watt panels of sale this weekend on Amazon, but can't use them.
06-11-2016, 10:11 PM
#75
Thanks!
SCD
06-12-2016, 01:15 AM
#76
2007 WildCat 32QBBS
If one was to buy 2 kits of the 2x 165 panels what controller do you recommend from the same seller? I see they offer a 20amp.
06-12-2016, 09:28 AM
#77
If you are buying 4 panels the 20 amp controller will not be enough. Each panel will put out about 9 amps each at ideal conditions. My recommendation and several others is the Bogart Trimetric controller with the battery monitor.
home - Bogart Engineering
1978 Ford Rollalong
06-12-2016, 12:47 PM
#78
Waited too long to buy the Renogy 30 amp Viewstar controller. They are out of stock. They do have the 20amp, but will that be enough to handle the 3x100 watt panels I will be buying. The rating is 5.29amps (imp). That's just under 16 amps for a 20 amp controller, should be ok, right?
I know there are other controllers out there that are better, but I have had great success with my Renogy Suitcase and the Viewstar 10amp controller built in. Plus I already have a Xantrex battery monitor and don't need the added expense of another one like in the Bogart system.
06-12-2016, 06:31 PM
#79
20 amp controller for the output of your panels should be enough. Have you decided on how you are going to mount them?
1978 Ford Rollalong
06-12-2016, 07:18 PM
#80
Yes, I'm going to use the StickyFeet as I don't want screws in the roof. Not sure if I'm going to use 4 or 6 per panel. Maybe 3 each on the longer sides or maybe 2 each on the longer sides and 1 each on the shorter side that will be facing front and back. Do you think that's overkill?
