Old 05-28-2016, 06:40 PM   #71
Sagecoachdriver's Avatar
Here's the photo with dimensions. I thought this would keep the shadow from the A/C at a minimum and would partially block air flow while driving. Could put one behind the vent also and one in front instead. What I meant on the Sticky feet was 2 on each side as it's almost square equals 8 times 2 is 16. I suppose I could get by with 2 each on the slightly longer side and 1 each on the other sides.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 0trips 0 nights
Sagecoachdriver is offline   Reply With Quote
Old 05-29-2016, 02:16 PM   #72
If you scroll way back on this thread, you'll see Wolfwhistle's 150watt Renogy panels that I may get. I know 200 watts total at 11amps isn't going to recharge the house batteries after a 45-60 amp draw down daily. Definitely need 300 watts at 17+ amps. So either 3x100 watt or 2x150 watt. I like Renogy even if it's a few bucks more. Good customer service.
Old 06-11-2016, 09:56 PM   #73
Almost ready to buy everything. Saved up Amazon gift cards.
HopHed, which panels did you buy again? I went on the roof today with a template and the Renogy 150 watt panels won't fit without getting too close to the A/c and have a shadow or too close to the vent and back of MH. Will have to either go with 3x100watt or 2x160watt from another brand. Renogy had the 150 watt panels of sale this weekend on Amazon, but can't use them.
Old 06-11-2016, 11:08 PM   #74
HopHed's Avatar
Here are the two links for the panels on ebay. I got the ones from everbright (165 watt) and put an offer in for the panels less the shipping price and it was accepted. I believe both panels are the same size or very close. Let me know if any questions.
2 160 Watt 12 Volt Battery Charger Solar Panel Off Grid RV Boat 320 Watt Total | eBay
2X 165 Watt Solar Panels Charging 12 Volt Battery High Efficiency Made in USA | eBay
1978 Ford Rollalong
2004 Fleetwood Tioga 29V
2016 Forester 2861DS (11-13-15)
HopHed is offline   Reply With Quote
Old 06-11-2016, 11:11 PM   #75
Thanks!
SCD
Old 06-12-2016, 02:15 AM   #76
2007 WildCat 32QBBS
05CrewDually's Avatar
If one was to buy 2 kits of the 2x 165 panels what controller do you recommend from the same seller? I see they offer a 20amp.
05CrewDually is offline   Reply With Quote
Old 06-12-2016, 10:28 AM   #77
HopHed's Avatar
If you are buying 4 panels the 20 amp controller will not be enough. Each panel will put out about 9 amps each at ideal conditions. My recommendation and several others is the Bogart Trimetric controller with the battery monitor.
home - Bogart Engineering
1978 Ford Rollalong
Old 06-12-2016, 01:47 PM   #78
Waited too long to buy the Renogy 30 amp Viewstar controller. They are out of stock. They do have the 20amp, but will that be enough to handle the 3x100 watt panels I will be buying. The rating is 5.29amps (imp). That's just under 16 amps for a 20 amp controller, should be ok, right?
I know there are other controllers out there that are better, but I have had great success with my Renogy Suitcase and the Viewstar 10amp controller built in. Plus I already have a Xantrex battery monitor and don't need the added expense of another one like in the Bogart system.
Old 06-12-2016, 07:31 PM   #79
HopHed's Avatar
20 amp controller for the output of your panels should be enough. Have you decided on how you are going to mount them?
1978 Ford Rollalong
Old 06-12-2016, 08:18 PM   #80
Yes, I'm going to use the StickyFeet as I don't want screws in the roof. Not sure if I'm going to use 4 or 6 per panel. Maybe 3 each on the longer sides or maybe 2 each on the longer sides and 1 each on the shorter side that will be facing front and back. Do you think that's overkill?
solar
