Old 12-11-2017, 07:39 PM   #1
Really my last winter question
Cant remove the bowl from the water filter! Just wont unscrew! Seems like there should be some kind of wrench. Any suggestions?
Forester1966 is online now   Reply With Quote
Old 12-11-2017, 07:47 PM   #2
My 3011ds came with a white tool that went around the filter bottle and then you would turn it to come off and take the filter off
Campincarters is offline   Reply With Quote
Old 12-11-2017, 07:48 PM   #3
sgtlm17's Avatar
Also make sure the system has no pressure. Pump off and faucets open.
2016 Forester GTS 2801QSF
sgtlm17 is offline   Reply With Quote
Old 12-11-2017, 07:49 PM   #4
DavidBo's Avatar
Head to your nearest hardware store / home center and pick up a rubber strap wrench. This will easily grip and remove the housing, just be sure to support where the filter mounts with your other hand or you could rip the whole thing loose!
DavidBo is offline   Reply With Quote
Old 12-11-2017, 07:50 PM   #5
bikendan's Avatar
Supposed to have a tool to unscrew the filter housing.
Equalizer WDH
Old 12-11-2017, 07:51 PM   #6
Scoundrel
HangDiver's Avatar
You should have a tool that looks like this. Can probably buy one at any decent hardware.
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 12-11-2017, 11:16 PM   #7
Novice Travel Trailer Guy
benchmarks's Avatar
Make sure your turning it the correct way.
2018 Flagstaff Micro Lite 25BRDS Travel Trailer
2018 Chevrolet Silverado 2500 LTZ
benchmarks is offline   Reply With Quote
Old 12-12-2017, 03:33 PM   #8
satdog01's Avatar
First time off with mine, almost broke plastic wrench in pic above. Used a wrench, almost no pressure and it spun lose.!
Marriot II on Wheels 2017 Flagstaff Classic 832OKBS Diamond Pkg
2013 GMC Denali crew 6.6L 2500 HD DMAX w\Alison Trans
Pepper 🌶 Pomeranian rescue 244 nights as camping buddy
Days camped in FR, 2011 = 20, 2012 = 57, 2013 = 59
....2014 = 39, 15 = 52, 16 = 77, 17 = 81, 2018 = 44
Retired :
satdog01 is offline   Reply With Quote
Old 12-12-2017, 03:46 PM   #9
Pickin' & Campin'
Which filter do you have?
If it's the FR1 you must first remove the pressure from the system, then push UP on the filter bowl to disengage the locking teeth, (it will only move maybe 1/8 of an inch) then turn the bowl with the wrench to loosen. (note: you can see the locking teeth in the second photo of the bowl)
To reinstall, tighten to align the arrows on the housing and the bowl and pull DOWN to lock the teeth. (note: arrows are not aligned in photo)
Days Camped: '15=22 '16=46 '17=30 '18=51
Old 12-12-2017, 06:14 PM   #10
benchmarks's Avatar
So to relieve the pressure then just open a faucet? Thanks for the differentiation on the type of canisters.
winter
