Old 11-19-2018, 08:57 PM   #1
Reduced Engine Power
Hi, we are newbie owners of a Sunseeker 2500TS. On our first longer trip, after gassing up, the engine was slow to turn over. When it did the check engine light came on and "reduced engine power". After turning it off (getting lunch) and starting again it went off. It did happen again after stopping, but once it was restarted it went off.
Should we be concerned or is this part of the "breaking in" process? Given that it only have 1100 miles, we want to be safer.
chestnutfree is offline   Reply With Quote
Old 11-20-2018, 08:09 AM   #2
RedLdr1's Avatar
Welcome to the forum. The symptoms you are describing are not normal nor are they part of the break in process.
I would be going to my local Ford dealer to get any codes in the computer down loaded to see why this is happening...
Wayne
2024 Sunseeker 2150SLEF / Ford E-350 Due for delivery 24 April 2024.
RedLdr1 is online now   Reply With Quote
Old 11-20-2018, 08:44 AM   #3
Garrette's Avatar
Check your gas cap for tightness. I think you can clear the check engine light by disconnecting the battery ground. If the condition returns, like Redldr stated, take it to a Ford dealer.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 11-21-2018, 09:01 AM   #4
Shredder's Avatar
Perhaps you take it to the dealer and have them plug in the scan tool to see if it stored any codes.
then again if it did the light would still be on.
2013 Forest River Sunseeker 3010DS
Shredder is offline   Reply With Quote
power
