Old 06-28-2018, 05:22 PM   #1
rick freeman's Avatar
Refrigerator tooo cold
Sometimes when i park my rig, 2017 Forester 2861 ds, the items freeze up.
Donít like frozen lettuce, does having the rv not exactly level create all this?
Just wondering
rick freeman is offline   Reply With Quote
Old 06-28-2018, 05:27 PM   #2
Duckogram's Avatar
No. Have you moved your temp sensor down? and, Have you considered a 12v circulation fan?
ILB ( | )
Old 06-28-2018, 05:28 PM   #3
DieselDrax's Avatar
You need to adjust the temp sensor slider on the fins in the fridge. The further up on the fin it is the colder the fridge will get, so if you don't want it that cold then slide it down the fin a little bit.
Not being level won't cause it to over-cool, no.
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
DieselDrax is online now   Reply With Quote
Old 07-01-2018, 09:58 AM   #4
Thanks for reply i am aware of the slide sensor but your interesting comment about circulating fan is something that I hadnít thought of.
Would you comment more? Thanks
Old 07-01-2018, 10:04 AM   #5
Move to Florida !!
Decon Blue is offline   Reply With Quote
Old 07-01-2018, 10:11 AM   #6
Carknocker Family
Ida Ratherbe Camping's Avatar
This is similar to what I use.
Ida Ratherbe Camping is online now   Reply With Quote
Old 07-01-2018, 10:18 AM   #7
Just wondering
Interesting dilemma...as most post are that the frig is too warm or having trouble keeping cool.
TheWolfPaq82 is offline   Reply With Quote
Old 07-01-2018, 10:21 AM   #8
Thanks for photo will look for 12v circulating fan for fridge
Old 07-01-2018, 05:58 PM   #9
Duckogram's Avatar
Here is what I use. Be sure to get the deluxe version. I got mine on Amazon but the seller also has their own website and lists on ebay. They may not all be the same and part numbers vary.
2800 QS Mods
ILB ( | )
Old 07-01-2018, 06:36 PM   #10
Carknocker Family
2800 QS Mods
This IS the one I use.
Had it wired into my fridge light at first but kept blowing the fuse on the circuit board. Had to run a dedicated wire through back of fridge to the 12 volt junction block behind. Fused of course
Old 07-01-2018, 06:42 PM   #11
I see everyone saying move the thermositor up or down to adjust temp, this is NOT universal.. for NORCOLDS, you move left or right..Not sure what unit you have.. However If it was fine before, and Now seems to freeze things, then your thermositor is possibly bad. pretty cheap off Amazon (about 15 bucks) and take about 5 minutes to swap out. FTR mine was a new 2018 model and it was bad from the get go. AT least if its too cold you can turn off your fridge for a bo, much better than if its too hot!
Ron and Kathy
2019 Cougar 369BHS 5'VR
2018 Cherokee Limited 304 BH (Traded)
Joyfully Towed with a 2018 RAM 3500 6.7 G56
ronheater70 is offline   Reply With Quote
Old 07-01-2018, 07:58 PM   #12
Duckogram's Avatar
Bad news. These are NORCOLD units and the THERMISTOR (thermostat + resistor) adjusts up and down. You can see it in the link I posted for the fan mod. It is to the right of the fan(s).
And for those scoring at home, here is a link to a reputable website that splains how to test that pesky thermistor. How To Determine If Your Norcold Thermistor Is Bad (thermistor troubleshooting) - The Norcold Guy
BTW, welcome to the Forester motorhome section.
ILB ( | )
Old 07-01-2018, 07:59 PM   #13
FYI, not all trailers are the same. Especially the ones with motors.
Well this is news to me, mine adjust left to right! I guess they have different versions, I learned something today!
Ron and Kathy
Old 07-02-2018, 08:12 AM   #14
BY the way, AWESOME edit to your post for the bottom dig Dude!!
I see the posts on the right side and pay no attention to the section its in, I think " I have a Refrigerator, they Have A Fridge, both probably run on Propane and Electric.Mine goes left to right, I thought they were all that way! But Maybe it is one of those Motor homes that the fridge runs on carrots and cabbage
BTW Link shows that they DO move right or left..https://www.arprv.com/norcold-thermistor.php
So maybe not all do it, or maybe some years dont, I do not know.
Ron and Kathy
Old 07-02-2018, 11:13 AM   #15
Total Loss's Avatar
Get an adjustable dial thermistor.
I have that and a circulation fan attached to the fins like a previous post.
Winter- I turn it down, summer I turn it up.
No more frozen lettuce since.
The dial indicator on the thermistor is much easier to use and you don't have to worry about moving it.
"If you are going through hell..keep going"
W. Churchill
Total Loss is offline   Reply With Quote
Old 07-02-2018, 02:45 PM   #16
Duckogram's Avatar
Sorry. The edit was made to increase the tonal quality but you captured the draft before I deleted it. There were actually two posts where only one was intended. The wifi at this park is marginal so it can be minutes before it updates.
For some reason I really have to work at tonal quality. Especially for the group I refer to (and have been for years) as the Roving Cabal of Towables. However, rest assured that I will continue to work on the tone.
Best Regards,
The Dude
ILB ( | )
Old 07-03-2018, 08:54 AM   #17
Duckogram's Avatar
I followed your link and I did not see any that adjust from left to right. So unless you are talking about actually moving the thermistor to a different cooling fin (not recommended) I must have missed it.
ILB ( | )
Old 07-22-2018, 09:52 PM   #18
In the Norcold 6.0 manual it says to adjust to the right if too cold. That is exactly what I did and now temp rests between 35 to 37 degrees.
dumboatt2 is offline   Reply With Quote
Old 07-23-2018, 09:35 AM   #19
Duckogram's Avatar
We must be talking about something different. Can you please post a photo of what you moved to the right.
ILB ( | )
Old 07-23-2018, 07:06 PM   #20
Sorry, I am of the age where this technology has left me in the dust. I would not have a clue how to send a picture, so I will do my best verbally quoting from the owners manual. I have the Norcold N611V. Yes, I am talking about moving the thermistor.
Quote manual: if you wish to change the fixed setting, you must move the thermistor.
Pull the thermistor and clip off fin.
Push thermistor and clip onto a different fin.
Move the clip to left for colder, right for a warmer temp.
Move the thermistor and clip only 3 or 4 fins at a time.
If more adjustment are necessary, repeat steps above. Unquote
I ended up moving the clip to the right as far as I could, I clipped the thermistor toward the top of the fin in order to move further to the right. Finally quit freezing the food on first self.
refrigerator
