07-05-2018, 02:42 PM
remote / Ford alarm
Does the Ford door remote when set arm an alarm? We have the Magic Start installed. Don't ask why, long story. Just want to know if that would change the Ford setup.
RETIRED U.S. NAVY
2017 FORESTER 3051S
IN SO-CAL
07-05-2018, 02:50 PM
All depends on your vehicle. You'll need to find out if it has keyless entry or an alarm.
2016 F150 XLT 4X4 SCREW 5.0
2014 Grey Wolf 21RR
07-05-2018, 03:13 PM
Yes, mine does.
Richard & Diane
2014 Cedar Creek 38FL
2016 F350 Lariat CC DRW
Retired Metropolitan Police (UK)
07-05-2018, 09:31 PM
It works as a keyless remote. Just not sure about the alarm part.
RETIRED U.S. NAVY
2017 FORESTER 3051S
IN SO-CAL
07-06-2018, 01:43 PM
If it is equipped with an alarm, first press locks doors second press of the button sets the alarm.
07-06-2018, 10:12 PM
what I have
This is what I have for the remote and the Magic crap.
RETIRED U.S. NAVY
2017 FORESTER 3051S
IN SO-CAL
07-07-2018, 05:34 AM
Yep. Lock/unlock and if you push lock again after locking the doors, you set the alarm. I have 2 Fords like that. Also if you hit the red button by mistake, that sets off the alarm!
07-07-2018, 07:01 PM
I had the window down on the driver side set it then opened it from the inside but it did not Set It Off could that be the reason because I opened it from the inside?
RETIRED U.S. NAVY
2017 FORESTER 3051S
IN SO-CAL
07-07-2018, 08:36 PM
Opening the door by reaching through the window should set off any alarm that has been set.
07-07-2018, 08:39 PM
Never tried it cause I don't use the alarm at all. I would think there is a,built in delay before it goes off.
07-07-2018, 09:01 PM
The ford remote controls the factory alarm (lock arms it unlock disarms it). As long as you are use them you should be fine.
Larry
2014 Ram 3500 Dually 4x4 6.7 Cummins
2017 Sandpiper 378FB
07-07-2018, 10:22 PM
I think you'll find the alarm is set with the first press of the button along with locking the doors. The second press is just to give you an audible signal letting you know the doors are locked and the alarm set. At least that's how I read what it said in the owners manual.
Richard & Diane
07-09-2018, 08:20 AM
update
Well I went over to the RV yesterday. I set the so-called alarm and opened the door from the inside, nothing. I am going to call Ford and the Magic people and find out what is going on.
Thanks for all your guy's inputs.
RETIRED U.S. NAVY
2017 FORESTER 3051S
IN SO-CAL
07-09-2018, 08:22 AM
Did you check for a fuse for the alarm? Maybe it does not have an alarm or disconnected for the start function.
07-09-2018, 08:32 AM
The buttons work normal, lock / unlock and beep on the second push. Just not doing anything when opening the door. That is where I think they may have disconnected the alarm part when they installed the "Magic" thing. Thanks
RETIRED U.S. NAVY
2017 FORESTER 3051S
IN SO-CAL
