Old 08-13-2019, 07:44 PM   #1
raoulwv's Avatar
Removing ceiling AC grills
ID:	212318 Has anyone removed the ceiling AC grills on your rig? How do you do it without causing damage? Mine have the adjustable louvers and spin all the way around.
Rod & Carla B.
The Hounds Kooper & Abby
2015 Sunseeker 3010; '18 Ford Focus toad
raoulwv is offline   Reply With Quote
Old 08-13-2019, 07:52 PM   #2
Dcbenny's Avatar
If you look up inside vent you will see the tabs I used a butter knife between the vent and the outer rim a gently pried them off once you get one side to snap loose the rest of it comes off very easy
Don & Liz B.
Pink Retired Greyhound
2016 GTS 2800QSF
Dcbenny is offline   Reply With Quote
Old 08-13-2019, 09:11 PM   #3
A tool set that has helped me immensely when it comes to prying on plastic things is the 5 Piece Trim and Molding tool set from Harbor Freight. They are basically plastic pry bars of various shapes. Being plastic themselves, they don’t mar or gouge your work piece. They’re strong; I haven’t broken one yet.
https://www.harborfreight.com/trim-a...-pc-64126.html
BehindBars is offline   Reply With Quote
Old 08-13-2019, 10:11 PM   #4
HONDAMAN174's Avatar
Yes- the Barbie tool set is great to have.
Just glad to get away
HONDAMAN174 is online now   Reply With Quote
Old 08-14-2019, 07:40 AM   #5
Bonjoey's Avatar
Thanks for this! I have to clean ours because it has some broken or leftover styrofoams in it ��
2019 FR Sunseeker 2650S E450SD
Bonjoey is offline   Reply With Quote
Old 08-14-2019, 01:30 PM   #6
Cover Dog's Avatar
Send a message via ICQ to Cover Dog
I remove ours monthly in our ducted system, just pull them straight down. Our intake ducts, we have 4 in the living room/kitchen area and 2 in the bedroom, do not have movable louvers but do have foam filters that we clean monthly.
The ducts where the AC air comes out do have movable louvers and these we have not removed.
Bill, Maura & Rosie the rescued Boston Terrier
2016 Winnegbago Adventurer 38Q....26K Chassis
...traded in 2015 FR Wildcat 282RKX
2014 CR-V EX-L w/Nav & Blue Ox & Ready Brute Elite
NRA Endowment Life Member, FMCA #455593, WIT #170814 & Mid-Ohio Winnies
Cover Dog is offline   Reply With Quote
Old 08-14-2019, 06:05 PM   #7
Old Engineer
FleckDreher's Avatar
[QUOTE=BehindBars;2162639]A tool set that has helped me immensely when it comes to prying on plastic things is the 5 Piece Trim and Molding tool set from Harbor Freight. They are basically plastic pry bars of various shapes. Being plastic themselves, they donít mar or gouge your work piece. Theyíre strong; I havenít broken one yet.
I 2nd this
Everyone should have these tools in their RV, very useful, prevents damage to surfaces.
2019 Dynamax Isata 3 24RW
Smart Car Towed 4 Down
Quote: "When all else fails, read the manual!"
FleckDreher is offline   Reply With Quote
Old 08-14-2019, 06:06 PM   #8
Old Engineer
BehindBars;2162639 A tool set that has helped me immensely when it comes to prying on plastic things is the 5 Piece Trim and Molding tool set from Harbor Freight. They are basically plastic pry bars of various shapes. Being plastic themselves, they don’t mar or gouge your work piece. They’re strong; I haven’t broken one yet.
I 2nd this
grill, sunseeker
