Old 12-04-2019, 01:48 PM   #1
Replacement gas tank filler hose
My 2014 3100 started to not take gas upon fill-up. Inspection shows a good kink in the fuel filler hose above the gas tank. Hose will need to be replaced and tank dropped to do it. Kink is pretty much at the edge of the tank as there is not enough clearance for a smooth bend. It would be nice to replace it with a molded 90 degree hose rather than putting back on one that will fail again in the future. Anyone know of a source for a 90 degree molded line?
ActionJackson is offline   Reply With Quote
gas, replacement, tank
