Originally Posted by blue daze
Thanks for all the input. It is now a moot point, as we discovered the Big Foot doesn't work at all. Lights flash, nothing happens. I had our local mobile RV repair look at it, and he couldn't find the problem without taking it to his shop and putting on the the lift, so we'll see if we want to spend the money. So, what are the best leveling blocks for a class C?
There are some interlocks for the Big Foot to prevent operation. One is the engine running. I think the other is transmission in Park, not Neutral (or any other gear).
Also, there is a fused 30 amp power supply that does not come from the controller. The controller just supplies the control signals to each of the hydraulic pumps.
I would would first check the interlocks. It's easy to overlook using the Big Foot with the engine running. I've done it a couple times myself.
Bobby
