Old 10-03-2015, 07:10 AM   #21
Imo fix your bigfoot system you will not regret spending the money.
lbrunning is offline   Reply With Quote
Old 10-03-2015, 09:08 AM   #22
Originally Posted by blue daze View Post
Thanks for all the input. It is now a moot point, as we discovered the Big Foot doesn't work at all. Lights flash, nothing happens. I had our local mobile RV repair look at it, and he couldn't find the problem without taking it to his shop and putting on the the lift, so we'll see if we want to spend the money. So, what are the best leveling blocks for a class C?
There are some interlocks for the Big Foot to prevent operation. One is the engine running. I think the other is transmission in Park, not Neutral (or any other gear).
Also, there is a fused 30 amp power supply that does not come from the controller. The controller just supplies the control signals to each of the hydraulic pumps.
I would would first check the interlocks. It's easy to overlook using the Big Foot with the engine running. I've done it a couple times myself.
Bobby
bgilly is offline   Reply With Quote
Old 10-03-2015, 10:21 AM   #23
Boso's Avatar
Call Bigfoot company they may be able to tell you what to do to reset the jacks
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 10-07-2015, 08:34 PM   #24
Big Foot
The engine was not running. We were plugged into shore power at the house.
blue daze is offline   Reply With Quote
Old 07-03-2017, 12:59 PM   #25
This happened to me and I called the rv dealer, they told me to unscrew the face plate , unplug the wire for a minute replug and it should a work again. It works again
Robert 3 is offline   Reply With Quote
Old 07-07-2017, 07:59 AM   #26
sgtlm17's Avatar
It is possible your Bigfoot just needs to be reset. A common problem when battery falls below a certain level. Even after charging battery the Bigfoot system will not reset automatically. You must reset it manually by unplugging control board for 30 seconds. Watch this video https://youtu.be/DCn3gW9PhMM
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
airbags
