Old 04-21-2015, 03:31 PM   #1
ourflat's Avatar
RM1350 Icemaker Not Working
My icemaker would not work in my RM1350 refrigerator this season. I bleed the water lines and it still didn't work. I pulled the icemaker to troubleshoot and discovered the micro switch that controls the water solenoid valve was not working properly. I found the part online, after replacement, icemaker works like a champ once more. Just another FYI for anyone who has the same problem as I did.
Frank
Frank
2016 Days Camping so Far: 24
2013 3051S Forester
2013 Elantra GT (Toad)
WashU EMBA "39
ourflat is offline   Reply With Quote
Old 04-21-2015, 05:37 PM   #2
Mine was acting up last season was it hard to pull the ice maker out? (same unit as yours)
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 04-21-2015, 06:05 PM   #3
ourflat's Avatar
I agree! I used a step stool to gain an advantage, then, I had at it with those two long screws
Frank
Frank
2013 3051S Forester
WashU EMBA "39
Old 04-21-2015, 08:25 PM   #4
Frank
Hey Frank : I was asking" IS " it hard to pull the icemaker out, haven't tried it yet, . How do you do it?
2014 Forester 3051s
2012 Sonic toad
Old 04-21-2015, 08:51 PM   #5
ourflat's Avatar
Ohhh, there are 4 Philip head screws, and an electrical connector. Remove the 2 lower screws (pretty long screws) then loosen up the top 2 screws. Lift up on the icemaker and disconnect the electrical connector. You can then remove the icemaker. After you remove the icemaker, you can remove the side cover, then remove the 3 screws to expose the motor and micro switches. The ice maker solenoid is operated by the lower micro switch. You can ohm out the switch to make sure it is defective. If you get this far and can't find the problem, then you can temporary hook up the electrical connector and jump the micro switch to make sure your water solenoid is allowing water to flow to the ice maker (disconnect the water outlet hose to let the water flow out the access panel). Also make sure your water valve is pushed in under the refrigerator and that you are getting water to the solenoid. I found a used ice maker for parts online along with the micro switch. A new ice maker is about $170.00.
Hope this helps,
Frank
Frank
2013 3051S Forester
WashU EMBA "39
Old 04-22-2015, 08:53 AM   #6
Thanks for the info, will look into this when(?) I get mine back from dealer for slide repair.
2014 Forester 3051s
2012 Sonic toad
