Old 07-26-2015, 01:45 PM   #1
roof A/C
The roof a/c on my 2251 is draining humidity off the right front roof gutter. Is this normal or should it be draining somewhere under the truck. What are the two plastic tube under the coach door, one blue and one red and screw on type black covers
poppytoymaker is offline   Reply With Quote
Old 07-26-2015, 01:48 PM   #2
Those are hot and cold water low point drains. Ac will drip from roof.
2006 Honda Goldwing
2012 Toyota Tundra DC s(sold)
2015 Cherokee Grey wolf 19RR Limited
2017 F150 Super Crew 3.5eb 5.5
bluewoo is offline   Reply With Quote
Old 07-26-2015, 01:55 PM   #3
trbomax's Avatar
Watching the condinsate drain off is a good way to tell how level you are.Water runs downhill.
trbomax is offline   Reply With Quote
Old 07-26-2015, 02:02 PM   #4
Witch Doctor's Avatar
There is nothing wrong, if your A/C water is hitting your side of the unit add an extension to the gutter drain. You don't want it dripping on the fiberglass.
Coachmen M/H
Concord
2018 / 300 DSC
roo, roof
