Old 05-26-2016, 02:06 AM   #81
Sagecoachdriver's Avatar
Originally Posted by Creativepart View Post
Nope. They don't exist. I'm using the two red lenses and having no problems.
Still under warranty? What does the dealer and FR have to say about it?
If I remember correctly, they are oval and fit flush with the cabover, right? So the recessed area may be different than the current models.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 0trips 0 nights
Sagecoachdriver is offline   Reply With Quote
Old 05-26-2016, 11:03 PM   #82
skylilymd's Avatar
There's a place called Blake sales I bought two from - it was expensive like 30$ (he kind of has a monopoly on them lol) but I bet he still has some 773 927 3350
skylilymd is offline   Reply With Quote
Old 05-28-2016, 06:42 PM   #83
BEFUDDELED MEMBER
FYI
This is what hazmat clean up use for black mold remeadiation.
You want to go to Lowes or Ace and get CONCROBIUM MOLD CONTROL
It eliminates and prevents black mold. It is not bleach, alcohol or ammonia, contains no harsh chemicals.. It comes in a spray bottle. Saturate area and it will remove the stain, kill and prevent new mold growth and eliminate the musty smell .
13,SUNSEEKER 3010
RETIRED / New Mexico
KZ5PZ - EXTRA -
Viet combat vet USNR
DAV, VFW, CCL. SASS
shooter2 is offline   Reply With Quote
Old 05-28-2016, 07:02 PM   #84
BEFUDDELED MEMBER
My post on the oval yellow clearance lite issue on IRV2 site:
" I believe you are asking about the oval yellow clearance lights on the front cap. You did not indicate location or color. The front clearance lites / lenses are classified as obsolete/ unobtanium/ hens teeth. Do google/ what ever search engine to try to locate some. I have accumulated 2 yellow lenses and 5 of the 2014 oval LED yellow light assemblies over the last 2 years, The quest for the holy grail started when someone stole 2 at the local RV dealer while in for a fridge repair. I have found one at a time at small RV shops in 7 states.
Since I have 5 replacement LED complete lites, I have glued the current lenses on the Incandescent lamp assy on the RV. The Fiberglass front cap was molded for these unique oval lights available only from the one mfg.. You might see if the new round lites will fit. Try the Frogs website: http://www.forestriverforums.com/forums/
Good luck __________________
JACK ( KZ5PZ ) & SHIRLEY 13 SUNSEEKER 3010 w/ 5 STAR, SOLAR, ++
The Bichons: KIBBELS & CHIPS and forever remembered BITZ
DAV-LIFE, VFW-LIFE, NRA-LIFE, SASS-LIFE, GOOD SAM-LIFE, NM-CC,"
13,SUNSEEKER 3010
KZ5PZ - EXTRA -
DAV, VFW, CCL. SASS
Old 05-28-2016, 08:42 PM   #85
Lights and leaks
On the older style oval lights it is true - they are no longer made. Glo-Brite closed down and no one has made the light to replace that unique style - believe me I've looked around. I bought the LED version of the oval lights but the sun attached the bases and they became very brittle. I bought the fixtures from benlorv.com.
Only suggestion I can make to replace the extinct oval is to have base plates made the same as the oval and install a different fixture onto the base plate. I made some base plates out of 3/16" aluminum and secured the new LED Glo-Brite fixture to the plate. I had too many leaks even with the new fixtures and I felt it was due to the molding base of the light. The plate gave me a flat surface to work with. I used Loctite gasket maker to seal everything. I tested by pressurizing the ceiling and and applying soap around the fixtures. They are now air and water tight.
For all - check your clearance lights regardless of the style - they will leak water into the over-cab.
On leaks - I don't recommend creating a drain hole. The drain hole will allow water to drain out but it doesn't fix water getting in.
I've had leaks from all areas around the front cap; at the top where cap and fiberglass roof come together, at the cap and rain gutter and at the cap to the van chassis roof (the connection of the fiberglass cap to the cutaway van roof). I suggest performing pressure checks and use soap. Pressurizing the roof is easy using a powerful blower connected at where the ceiling LED light is. I pulled an LED ceiling light and connected my blower to a high pressure flex duct, stuck the duct in the opening of the light. I went to town on the roof with a sprayer filled with soap water.
I've written on this forum extensively in regards to my leaks. Do a search on my post to get the details.
(Sorry about the blower photo - I couldn't get it to rotate)
Bobby
ID:	109399   Click image for larger version
ID:	109400   Click image for larger version
ID:	109401   Click image for larger version
ID:	109403   Click image for larger version
bgilly is offline   Reply With Quote
Old 05-28-2016, 09:07 PM   #86
Can't the clearance light depression be modified to use the 3/4" button Led lights?
Old 05-28-2016, 09:52 PM   #87
It can but it will take some work. You can't install the button lights as is because you will still have the mounting screw holes from the oval fixture.
Old 05-29-2016, 09:48 AM   #88
The wife and I have been closely following this roof leak issue (Windows, seams, lights, corners) on these units, and have now postponed our order of an 3011DS.
Not to mention those of you who ordered , waited, and then found your new units with scratched counter tops, torn materials, screws through the counter tops, etc. these do not sound like NEW units to me!
It's hard to believe FR ( or anyone) would allow these units to leave the factory in this condition, dealers would except these units in these conditions........and dealers would then sell these units in these conditions (obvious visual issues of scratches, torn materials, etc).
Our plan was to order.....fly up......drive home. I would not except a new unit in USED condition! I now wonder about those who have ordered, and had units delivered that showed up in these used conditions? I would walk out to my driveway, look the unit over, ask the driver what happened.......offer him or her lunch, and tell them to drive it back!
Can you imagine buying a new $75,000 plus car or truck and having the sales person explain that yes, the roof leaks, the seats are torn, the dash has a long scratch across it........just bring it back, drop it off for a month at service and we will patch it, cover it, glue it.......LOL !
1930 lbs CCC
2014 Jeep Rubicon JK
steeljag is offline   Reply With Quote
Old 05-29-2016, 09:56 AM   #89
I'm with you
Had I known ahead of time about (in my case) the poor build quality, the poor to non-existent warranty service in my area, the lack of warranty support from the manufacturer - I would have looked long and hard for a one year old unit. Then I would have had zero expectations of any kind of warranty service and paid a lot less.
I don't know why we tolerate this kind of attitude from the manufacturers and the dealers.
KatanaPilot is offline   Reply With Quote
Old 05-29-2016, 11:44 AM   #90
skylilymd's Avatar
Katanapilot - you are exactly right and to be honest with you this doesn't just apply to rv's it applies to cars, houses, and really anything if you buy brand-new expect to lose most of your money in the first year and have to deal with issues that come along with anything that you buy new. This forum is invaluable and I read it for a long time before I purchased my three-year-old previous rental with 80,000 miles on it - and while that may scare a lot of people, other than the purchase price I have put less work and money into it than some people who have bought new ones lol
Steel jag - there is actually nothing wrong with Forest River they're the same as any other manufacture even if you buy a Tiffin allegro you will still have to deal with issues related to water and physics - just don't buy a new one by a used one and when you buy it by it for cheap enough that you could put money into it in the worst case scenario and still come out on top and happy - Buy from a private party get it inspected if you don't feel that you're an expert on mechanical and or the coach itself, and then if you have issues (which you will no matter what u buy) it's not a big deal and you won't feel as stressed out. This is just my personal opinion of course
leak, roo, roof
