Old 11-22-2015, 06:16 PM   #1
Sagecoachdriver's Avatar
Roof mounting Solar Panels on Class C
I thought I did a topic back before I bought my Forester, but must have deleted it or maybe I'm having a senior moment. Anyway, now that I've had the MH for a few months and made a few trips, I'd like to ask if any Forester or Sunseeker owners have added roof top solar panels. The roofing material on mine is kind of ribbed/dimpled and not a smooth surface. So I wonder about using 3M adhesive tape or such,, or is drilling and screwing a better method. It has been suggested to route the cable down the fridge vent, but mine is opposite where the house batteries are. That probably means routing cable underneath to the step compartment.
I currently have a Renogy 100 watt solar suitcase which does a fine job when I use it. But I am always worried it will grow legs so I only use it when I'm around. I want to have the batteries charging all the time when sunlight is available.
I would like to mount 200 watts of panels and use a 20 or 30 amp controller.
ID:	94802   Click image for larger version
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
Sagecoachdriver is offline   Reply With Quote
Old 11-22-2015, 06:38 PM   #2
Found Renogy kit on sale next week
Found that Renogy will have a 15% off sale on Cyber Monday and the 200 watt kit with the upgraded 30 amp controller (OPTION 2). This may be the one! Easily expandable too!
200 Watt 12 Volt Monocrystalline Solar RV Kit | Renogy Solar
Old 11-22-2015, 08:36 PM   #3
Boso's Avatar
The ones I had were installed on AC shroud from factory
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 11-22-2015, 09:35 PM   #4
Boso, can you post a photo and how large are they?
Old 11-23-2015, 12:32 PM   #5
Check out my post/pictures, my roof looks like yours I think
Solar question....
2016 Rockwood Ultra Lite 2604WS
2018 Dodge Ram 3500 CTD SRW 4x4 Laramie
1993 Jeep Wrangler YJ IL6 4.0 lifted (love it)
Happy Trails All!!
roaddiva is offline   Reply With Quote
Old 11-23-2015, 02:16 PM   #6
Roaddiva, how are they mounted and did you leave air space below?
Old 11-23-2015, 02:38 PM   #7
I used extra strength double sided tape (read through the thread if you have time), works great. There is a small gap on the outside edge of both panels due to my roof is not flat. I will be putting weather stripping in those gaps.
Happy Trails All!!
Old 11-23-2015, 03:11 PM   #8
Before I bought my Sunseeker, I was planning to use 3M tape to attach solar panels to the roof of the RV I would eventually buy. I was a bit disappointed that the SS roof is textured, and therefore not a good candidate for tape. I have since researched the subject and found many instances of people using 3M 5200 Marine Adhesive Sealant to attach the solar panel standoff brackets to the roof. 5200 is a serious adhesive, used for below waterline applications. It is extremely tenacious and is permanent. From what I've read, aerodynamics will send most of the wind's force above the roof, leaving the panels mostly unaffected so you shouldn't need to use screws. Of course some screws in the front set of brackets could give some peace of mind.
Here's a link to one discussion I found on the subject:
RV SHRINK, Common Sense Peddler: Stuck on Solar
There has also been some discussion on iRV2.com
2016 Sunseeker 2300C
"The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts." - Bertrand Russell
SS Cruiser is offline   Reply With Quote
Old 11-23-2015, 06:40 PM   #9
A32Deuce's Avatar
I have a 3100SS with 305 watts of panels on the roof. I drilled and screwed the panels to the roof using Dicor between roof and bracket and then over screws. Same as the roof vents are. Ran the wires down refer. chim. to controller then to bats. Has been fine for 3 years so far.
A32Deuce is offline   Reply With Quote
Old 11-23-2015, 11:25 PM   #10
vwexpert's Avatar
Here is the one my dealer installed - 160 watts.
Name:	photo 1 (1).jpg
1971 20ft fireball (too small)
1987 27ft Tioga (bad brakes / tires)
1998 36ft Discovery (rattles / air leaks)
2005 37ft Monaco Knight (lemon Lawed)
2008 40ft Monaco Diplomat (too big)
2016 Forester 3011 (ordered June 8th - Born Aug 6) IT'S HERE
vwexpert is offline   Reply With Quote
class c, mount, roo, roof, solar, solar panel
