Old 09-26-2018, 02:11 PM   #1
dcheatwood's Avatar
Roof run off on to door
A few months ago I read a comment about the roof water draining on to driver's door controls when the door is open on Forester E450. Can't find the thread now. Do any if you remember if someone found a solution for this? A/C condensation and rain water pour out the spout just above door. When door opens, it floods the power lock/window controls and soaks the driver getting in and out.
2018 Forester 3011 DS
Old 09-26-2018, 02:26 PM   #2
rsdata's Avatar
I would consider putting an add-on to the downspout to redirect the runoff water either farther out, or to the front...
maybe something as easy as a short length of flexible plastic tubing with an inside diameter about the size of the drip spout, jammed onto the spout... then removed when driving. They have that type at the local hardware store.
ďToo much of anything is bad, but too much good whiskey is barely enough.Ē Ė Mark Twain
2014 Shamrock 183
Old 09-26-2018, 02:52 PM   #3
Dcbenny's Avatar
I added spouts to gutters on front of both passenger and driver side
ID:	187602   Click image for larger version
ID:	187603   Click image for larger version
Don & Liz B.
Pink Retired Greyhound
2016 GTS 2800QSF
Dcbenny is offline   Reply With Quote
Old 09-26-2018, 07:51 PM   #4
Usually Confused Member
emm-dee's Avatar
Good idea about extending drain with some plastic hose. Got some of that left over from the refrigerator drain mod so I’m going to give it a try. Meanwhile I’ll continue to just throw a thick towel over the top of the door extending down past the armrest and switches.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
emm-dee is online now   Reply With Quote
Old 09-26-2018, 08:20 PM   #5
2012 Solera
Two previous suggestions - apparently clipping a spring type clothespin to the end of the gutter spout results in the water running out to the end of the clothespin before coming down. Also, someone suggested cutting up a gallon milk jug handle to make a gutter spout extension.
I bought Camco (as I remember) extensions and glued on with GOOP. They have stayed on for four or more years so far - but the Camco extensions are a little short. I have to be careful how far I open the doors when it is raining.
JLeising
2012 Solera "S"
Calif SF Bay Area
JLeising is online now   Reply With Quote
Old 09-27-2018, 09:02 PM   #6
dcheatwood's Avatar
Some good suggestions here. My 3011ds came with down spouts already installed and a short extension will not make any difference. However, I've already thought about the tubbing over the spout. It'll take about 2 feet of tubing but may be best solution. I was hoping someone had already solved it and would give up the secret. 🤣
Old 09-27-2018, 09:40 PM   #7
Kirk S's Avatar
Other than the suggestions here I haven't found a better solution. I was surprised to learn that my original gutter spouts are flexible plastic so cleaning and gluing a plastic extension should work fine with the right adhesive.
Kirk
2017 Forester 3051S
Kirk S is offline   Reply With Quote
Old 10-26-2018, 12:23 PM   #8
Added these gutter extensions to my Forester, now the water misses the inside of the door Get the long ones. Just took the screw out holding in the old one and slipped the new ones in place.
https://www.amazon.com/Gutter-Spout-...ter+extensions
2015 Forester 2901
2005 Scion XB
RacerRalph is offline   Reply With Quote
Old 10-26-2018, 09:12 PM   #9
dcheatwood's Avatar
I'll have to check those out. Thanks.
door, forester, roo, roof
