Old 09-30-2016, 01:39 AM   #1
Sagecoachdriver's Avatar
Roof Satellite to Bedroom/Outdoor TV's
CreativePart, you're up on this.. I now have a ladder mounted Sat dish using the roof Sat connector up front on the roof. I connect the sat receiver to the middle connector on the plate shown below and all works well for the cabover TV 32" Jensen. What I did for the outside TV 32" Jensen was to run an HDMI cable down the wall behind my couch and up to the sat receiver and get a GREAT picture. But since I have the Dish ViP211z receiver, there doesn't seem to be a way to use satellite to the bedroom. Can't really run an HDMI cable back to the bedroom and somehow thru the wall. No regular cable connection on the back of the sat receiver. Is there an adapter that will allow me to take the HDMI cable and use an apter to plug into the bottom connector on the plate below?
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
Sagecoachdriver is offline   Reply With Quote
Old 09-30-2016, 03:35 PM   #2
sgtlm17's Avatar
I am looking for the same type of adapter. No luck so far.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 09-30-2016, 07:04 PM   #3
I used an RF Modulator similar to this one:
https://www.amazon.com/RCA-Compact-R.../dp/B0014KKV7W
My sat receiver also had no coax output, but did have composite video output in addition to the hdmi that I used for the front TV. The RF Modulator converts the composite signal to coax and I then used the existing coax cables in the RV to get to the rear and outside TVs.
2017 Forester 2861DS
towing 2015 Jeep Rubicon
fobagbob is offline   Reply With Quote
Old 09-30-2016, 07:57 PM   #4
crunchman12001's Avatar
I used an HDMI splitter for my ViP211z to my bedroom TV. Went through 2 walls, under shower and bath vanity. Different model but it is all possible.
An HDMI splitter is the only way to get HD signal to both sets.
2015 F-250 FX4
Old 09-30-2016, 10:47 PM   #5
I have one and will give it a try tomorrow. My 400w inverter should handle both the sat receiver and RF modulator. Thanks
ID:	121779   Click image for larger version
Old 10-02-2016, 09:47 PM   #6
Creativepart's Avatar
Ii had a 211Z and it had a RF output coax connection that I connected to the bottom connector on that 3-coax plate. But I replaced that with a new Dish "Wally" receiver last month.. The Wally doesn't have an RF output but does have component outputs. So I bought a $19 component-to-RF addapter at an electronics store, but Dish sells the same one. And now I plug that into the bottom coax connected on the 3-coax plate.
Unlike the 211Z the Wally has an RF remote rather than an IR remote. So it works the receiver from anywhere in the RV, even from outside.
I haven't tried one yet but there are wireless HDMI devices that will send the HDMI signal to your bedroom TV..
2017 Winnebago Adventurer 37F
TOAD: 2016 Lincoln MKX
Creativepart is offline   Reply With Quote
Old 10-02-2016, 10:36 PM   #7
Thanks, I haven't tried the RF modulator yet, maybe tomorrow. We have never used the bedroom TV other than to test it out once in a while. But it may give it a try where I can watch in the bedroom while the DW reads in the dinette area.
bed, door, outdoor tv, roo, roof, satellite
