Old 05-11-2016, 06:57 PM   #1
roof seam crack - vertical orientation, which sealant to use?
found a crack in the sealant in the seam where the front cap attaches to the roof. It's not a flat seam like a roof vent, and there seems to be a lot of conflicting info on what sealant to use.
Any recommendations?
thanks for your response.
2016 Forester 3051SF
MMulcahy is offline   Reply With Quote
Old 05-11-2016, 07:14 PM   #2
Who Dares, Wins
doc73's Avatar
Geocel Proflex.
I have also used Sikaflex as well to seal some seams. This is for up and down seams. Dicor on the roof seams (self leveling) or eterna bond tape.
Pat, Jen & Heather... Oh yeah and our trained attack trailer cat, Cinnamon
2015 ChevyHD D-Max
2014 Greywolf 26DBH
doc73 is offline   Reply With Quote
Old 05-11-2016, 07:26 PM   #3
I just used 4" eterna bond tape all around the perimeter of the roof. There was plenty of width for the front cap. It sticks really well. It should last longer than using just dicor.
Brian217 is offline   Reply With Quote
Old 05-12-2016, 12:11 AM   #4
skylilymd's Avatar
Is it on the side of the front cap or at the corner on top ? I only ask because I am currently repairing this on my forester - the front cap is screwed (underneath that vinyl trim piece) into the roof and sides with self tapping one inch screws - they are only grabbing into the thin piece of panel board on the opposite side under the fiberglass - they pull out after a while of use and that lets the seams crack and water comes in. I first noticed the dicor on the front right roof corner kept cracking after a trip and every time I sealed it it would crack again. I finally eterna-bonded the whole roof and all openings but water had got in the front right already. Now I'm almost done repairing it (which I will have videos of) - I took down the front cab ceiling all the way to the fiberglass and added a steel backer to the screws on the right side of the cap to bite in to - they were rusted and the last two were completely loose. This may not be the same issue you are having but if it is I thought I'd share what I found out. I have a 2012 3171 ds - fwiw I have found that if you have a small crack to seal the dicor seems to be more waterproof than eternabond especially on the textured fiberglass roof
skylilymd is offline   Reply With Quote
Old 05-12-2016, 12:29 PM   #5
Canadian Member
itat's Avatar
I use ProFlex RV on vertical seams where you don't want to use a self-leveling sealant.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer
2016 Ford F-250 XLT SuperCrew, 6.2L, 4x4, 6'9" bed, 3.73
Fondly remembered:
2009 Ford F-150 XLT SuperCrew, 5.4L, 4x4, 5'6" bed (2012 - 2016)
Old 05-12-2016, 12:37 PM   #6
Originally Posted by doc73 View Post
Geocel Proflex.
X2
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 05-12-2016, 01:38 PM   #7
thanks all for your responses
I'll give the ProFlex a try.
Old 05-13-2016, 08:22 AM   #8
eternabond tape
2016 Flagstaff 23LB
howie70 is offline   Reply With Quote
Old 07-23-2016, 06:43 PM   #9
Guys, thanks for posting these messages. I am having same issue as Sylilymd. I have a sunseeker 3100 2011 and front cap seal is separating from fiberglass roof. was at dealer today asking what caulk to use there and they had different opinions amongst themselves, kind of frustrating. Ended up with dicor self leveling lap sealant as directed by service tech but not sure if that is right or not. Does anyone have experience with that on fiberglass roof with what appears to be a rubber seal between the front fiberglass cap and the fiberglass roof? Also for vertical seams they gave me Nulex 313 but after I read the tube it says for glass and vinyl, ugh, doesn't seem right. Skyliliymd did you ever take the video of your repair? I would love to see it. Thanks for your help.
Jon S is offline   Reply With Quote
Old 07-23-2016, 11:12 PM   #10
skylilymd's Avatar
If you have a soft touch ceiling and you can't see any water stains or smell any musty smell then you are probly lucky - just clean that whole front cap seam on the roof and get some 4" eternabond tape and self leveling dicor. Tape it across the whole seam and what I did (not sure if it helps but made me feel better) is dicor the tapes edges so water can't go under. What I did to attempt to prevent it from happening again was add a thin piece of steel underneath the Luan plywood and screw the cap screws on that side down into it to grab better. You would not be able to do that of course unless you tore down the ceiling inside to get underneath that - which I would not recommend unless you clearly have a leak and water staining on the ceiling. I have roof pictures on the other roof leak thread here - I did take a video of the mold and damage but I didn't take one of the repairs because I was just trying to get it done lol - if u want to see that I can post it
roo, roof
