Old 07-08-2015, 06:23 PM   #11
Just bought Georgetown 270s. The tech said it was ok. He said do not run generator and shore at the same time.
Dwight
dwightfr270s is offline   Reply With Quote
Old 07-08-2015, 07:44 PM   #12
Citrus County, Fl.
GL1800Rider's Avatar
Our tech said it was ok to run generator while on shore as the transfer switch would take care of it
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 07-08-2015, 07:56 PM   #13
mike.t's Avatar
Don't know so i will ask. Why/when would you need both.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is online now   Reply With Quote
Old 07-08-2015, 08:02 PM   #14
You can run the generator while on shore power but why would you want to? It's true the transfer switch should protect the generator and unit electrical system from damage by preventing the generator from closing in. However you are unnecessarily challenging the system to function properly. If the transfer circuit fails say good bye to your generator not to mention the possibility of fire and frying of the electical system and things like TVs or other electronics connected.
This thread started with if you could run the chassis engine which is no problem as the main engine has no connection to the 120 volt system unless you have the inverter option to power some outlets via the 12 volt system.
ATVer is offline   Reply With Quote
Old 07-08-2015, 08:05 PM   #15
that would have been my reply to gl1800 but mike beat me to it. if it will help cooling or refrig I am for it. If not what would be the advantage. I will be going in Monday for some minor work. I will back.
dwight
Old 07-08-2015, 08:48 PM   #16
Garrette's Avatar
Originally Posted by mike.t View Post
Very informative.
sorry, working a shutdown. I should have finished before posting,
No, it makes no difference. run engine while plugged it or while genny is running. I run genny plugged in, I run engine while plugged in, I have run engine and genny while plugged in. Hope this is a little bit more informative.
Garrette is offline   Reply With Quote
Old 07-08-2015, 09:09 PM   #17
mike.t's Avatar
Thanks. So your NO was actually a yes?
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 07-08-2015, 09:10 PM   #18
Citrus County, Fl.
My thought process was to not have to disconnect the shore power line or open the breaker in the garage while I exercise the generator. I guess wearing out the breaker in the garage would be the least costly item to replace if transfer switch were to malfunction while plugged in....and sorry for changing the original post Hey at least were are still talking electrical
99 Terry 31G
Old 07-08-2015, 10:28 PM   #19
Garrette's Avatar
Well, yes, No, I mean no. Now you have me confussed.
Old 07-08-2015, 10:30 PM   #20
Garrette's Avatar
Screw paper mill shutdowns, lets go camping!!!!!!!
power
