Old 07-03-2015, 07:49 AM   #1
Citrus County, Fl.
GL1800Rider's Avatar
Running engine while on shore power
I spent an hour searching on here but can't find the answer. Can you start the engine on the MH to exercise it while on shore power or do I need to disconnect so it will not cause a conflict between the alternator and the converter? I know when you jump start a vehicle you need to disconnect the jumper cables immediately after starting so the alternators won't fight.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 07-03-2015, 08:54 AM   #2
bubbles's Avatar
The only issue would be if you drove off while still connected to shore power but all seriousness aside there are no issues or conflicts associated with starting your engine at any time.
Old 07-03-2015, 09:01 AM   #3
RSchleder's Avatar
I agree with bubbles. I've owned 3 different Class A diesel pushers and NEVER had an issue with running the engine while plugged into shore power. The transfer switch takes care of this for you.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 07-03-2015, 12:39 PM   #4
Garrette's Avatar
No
Garrette is offline   Reply With Quote
Old 07-04-2015, 08:02 AM   #5
Citrus County, Fl.
I thought the transfer switch was only for separation from shore power and the gen set to prevent back feeding thru the shore power umbilical cord.
99 Terry 31G
Old 07-04-2015, 08:55 AM   #6
Running the engine while hooked to shore power is no different than running generator while driving down the road as shore power and generator do the same function.
lbrunning is offline   Reply With Quote
Old 07-04-2015, 02:47 PM   #7
Citrus County, Fl.
Now that makes sense. Thanks
99 Terry 31G
Old 07-04-2015, 03:19 PM   #8
mike.t's Avatar
Originally Posted by Garrette View Post
No
Very informative.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 07-04-2015, 04:26 PM   #9
RETIRED
n-e-d's Avatar
Originally Posted by mike.t View Post
Very informative.
Yes
Mary and Me
2015 2650s "Finally"
2015 Jeep Cherokee
2016 Ford Race Car Red 350HD Cargo Van HR DRW EXT DIY Daytripper "My Little Red Corvette"
n-e-d is offline   Reply With Quote
Old 07-04-2015, 08:21 PM   #10
jtesta1's Avatar
its no different than putting a set of jumper cables to start a vehicle. long as your polarity is matched all will be kosher.
jtesta1 is online now   Reply With Quote
power
