Old 08-03-2016, 06:16 AM   #1
Running Frig on DC only
We will be going away next week and will be parking our 3011 somewhere for a few days while we stay in a hotel in the downtown area. I need to keep the frig running on batteries/propane for that time and expect that this would not be an issue. Anyone have any prior experience doing this and if so, how long did you run on batteries/propane only?
RVr
newRVer is offline   Reply With Quote
Old 08-03-2016, 06:23 AM   #2
There will be "Other Things" using that 12V as well just so you know! A few Days might challenge your Batt! Youroo!!
Old 08-03-2016, 07:07 AM   #3
Mainframe's Avatar
I would do a test run at home, I would flip all the breakers on the camper except the one that ran the fridge and see if it would run the length of time needed.
2016 Shamrock 23WS
2018 F150 Ecoboost
Mainframe is offline   Reply With Quote
Old 08-03-2016, 07:15 AM   #4
The breakers control the 120V! They are Not going to be "Plugged In"! Youroo!!
Old 08-03-2016, 07:31 AM   #5
There should be no problem running the fridge on battery/propane for a couple of days IF that were the ONLY thing running.
BUT... the problem is the other parasitic draws on your rigs 12v system.
I agree you should do a test run.
Things like CO detector, door frame heaters in the fridge (for condensation), fans, radios, etc. will ALSO be using 12v power while it is setting there.
Unless you've familiarized yourself with how to manage the 12v draw on your system (such as when boondocking) the battery may not last long enough to make the refrigerator stay running for that length of time.
Days Camped: '16=46 '17=30 '18=51 '19=42
Old 08-03-2016, 07:31 AM   #6
I have left the fridge on propane for more than a few days in my 3011DS with no issues. Just make sure all of the lights are turned off and you have a full propane tank/battery charge. The battery and propane tank should be good for only a few days with nobody in and out of it and using stuff.
77rednecktruck is offline   Reply With Quote
Old 08-03-2016, 07:50 AM   #7
Mainframe's Avatar
I was wondering if there are any 110 systems monitoring for battery power, that's why I mentioned flipping breakers, if I were doing this I would actually run a power wire right to the fridge under my camper and just disconnect the whole rig from the battery. Something like that might be nice to have in case of some type of emergency while traveling, like an unexpected TV breakdown or other weather related problem where you had to leave the camper for an undetermined amount of time and didn't plan to.
Looks like you have it covered in the other post by 77rednecktruckso you should be good to go.
2016 Shamrock 23WS
2018 F150 Ecoboost
Old 08-03-2016, 08:00 AM   #8
I will be parking it at our remote office about noon on a Tuesday with 2/3 propane and full batteries. I will be back Wed morning in the office so I can monitor it then. If need be, I may be able to connect to 120V during the day on Wed. I was hoping to be able to go from noon on Tuesday till 10am on Thursday without connecting to power.
Old 08-03-2016, 12:13 PM   #9
KJcachers's Avatar
Run the genny on Wednesday to recharge the batteries
2015 Forester 3051s
Jason and Karen
2015 Forester 3051S
2016 Ford Fiesta-Toad
https://www.visitedstatesmap.com/image/NCTNVAsm.jpg
KJcachers is offline   Reply With Quote
Old 08-03-2016, 12:51 PM   #10
camaraderie's Avatar
May I suggest you get an ACDC clamp meter and turn everything off in the rig and start with a warm fridge. Start up the fridge then clamp your positive battery terminal and see what the amp draw is. This will give you a sum of your fridge and phantom loads sot you can figure out how many amp hours you will be drawing when the fridge is on. Multiply by 24 for amp hours per day...and then multiply by how long you will be gone for what you will draw in WORST case with fridge on in hot weather full time.
Your draw for that time should be not more than 1/2 your house bank capacity.
If you have a pair of Group 24's...75 amphours max
If you have a pair of Group 27's...100
If you have Group 31's... 110
If you have a pair of Golf Cart 6V... 120
Obviously a lot will depend on the temps outside and in the coach...but this will give you a worst case...
If you visit the coach...a couple of hours on the genny can get you back to 80% full in most cases.
Hope this helps and here's an example of the clamp meter type I'm talking about. The cheaper ones are usually AC only current measuremet.
https://www.amazon.com/Uni-T-UT204-A...dc+clamp+meter
________
Cam
2015 Georgetown 280DS
camaraderie is offline   Reply With Quote
