Old 02-17-2016, 08:22 PM   #91
HopHed's Avatar
Haven't been to Rincon with new RV yet. We went to the Ventura RV park at the end of Main St 2 times. I leave at 5am and can always find a site with a little wait sometimes. Not sure how they enforce the 30 day rule there.
No surf fishing but may take it up when retired.
1978 Ford Rollalong
2004 Fleetwood Tioga 29V
2016 Forester 2861DS (11-13-15)
HopHed is offline   Reply With Quote
Old 02-24-2016, 05:20 PM   #92
Sagecoachdriver's Avatar
Wiring my 400 watt inverter today
Wired the 400 watt inverter for use with the Dish ViP211z receiver. According to my figures, it should only draw 4.5 ahr. So rather than drill a hole in the floor to the batteries, I opted to just attach it to wiring going to the outdoor entertainment center. At least for the time being. It's under the sofa and has Anderson quick-connects in line and a 7.5 amp fuse. There's easy access to the connectors and the inverter by removing the arm rest. Since we don't watch that much TV or Sat on the road, I'm leaving it unconnected.
This project is DONE! Now to enjoy and
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 10 trips 32 nights
Sagecoachdriver is offline   Reply With Quote
Old 02-26-2016, 07:43 PM   #93
Smile Sat and cable connections
Creativepart....thank you, thank you. I bought a new (2014) 3051S with 3 TV's and the sales team, technicians, etc., all said only the MAIN TV was wired for satellite. I've been scratching my head for some time now and always knew i could add a 'switch' box, run cables, etc., but it just didn't make sense to me.
Anyway, after reading this thread and the details you provided (which were very clear) i was able to get the satellite working for all 3 TV's from one (1) satellite box. I now only have a minor issue. The EXTERNAL TV only appears to have picked up some sort of interference (slight waviness in the picture). Again, only on the external TV and only on satellite. ANY IDEAS.
Otherwise thoroughly happy with our MH and certainly this forum.
Happy Camper
MMMndp is offline   Reply With Quote
Old 02-27-2016, 01:16 AM   #94
Creativepart's Avatar
We have the same issue. Like you it only on the SAT and only the outside TV. I think it's because the RF signal that is sent to the bedroom and outside is split between the two TVs. But I don't know.
If the Living Room TV is on then the bedroom TV's picture is full of noise, too. But if you turn off the Living Room TV then it clears up.
I don't know but it seems the outdoor TV problem is related somehow.
I want to try a few solutions, but I watch the outdoor TV so little that I haven't taken the time to try a few things yet.
2017 Winnebago Adventurer 37F
TOAD: 2016 Lincoln MKX
Creativepart is offline   Reply With Quote
Old 02-27-2016, 02:06 AM   #95
HDMI to O/D TV and bedroom
Creativepart, I thought I would just plug in a 10 foot HDMI cable from the outdoor TV and run it thru the opening where the O/D radio wiring enters the coach and under the sofa. Then follow the receiver power cord from the inverter, also under the sofa, back up to the receiver. I can switch HDMI cables from cab-over TV to outdoor TV. Yes, it's near impossible to run HDMI to the bedroom TV, but I'm thinking about it! Maybe wireless is the only option.
Old 02-27-2016, 08:16 AM   #96
I've heard of "HDMI over Coax" devices that let you get HDMI quality signal via long runs of RG cable. But have not done the research into this option yet.
The bedroom TV picture is acceptable to me and I use the outside TV so little it hasn't been a priority.
