Old 02-14-2016, 03:34 PM   #71
Sagecoachdriver's Avatar
Test run of Sat, receiver and inverter
Ran a test run of new Pathway X1 dish, with ViP211z receiver and 400 watt inverter. I put alligator clips on 10' lengths 10 awg wire attaching it to the battery positive and shunt negative. Then ran wires atop the sofa cup holder board. Placed the receiver on the cabover bed storage cover, but the HDMI cable was too short (6') to reach the TV as shown in photo. Will buy a long HDMI so as to hide it from view.
The DW saw it and said, "I hope you don't think you're going to leave it like that". She hates wires. I did a test and the 400 watt inverter did fine. Only draws 6.1 amps shown in photo of Xantrex Battery monitor and that's with the fridge going also and 2 lights. Simulated evening of watching Sat TV.
Since it draws so little amps, I thought maybe attaching the inverter to the power going to the outdoor entertainment center wiring under the sofa. But it may be an issue when we want to use the outdoor TV with SAT.
I did try the flat coax thru the window and got a screen saying "Cable signal Lost, check connections". I removed the flat coax and ran it directly to the receiver for now. Works GREAT!.
ID:	99592   Click image for larger version
ID:	99593   Click image for larger version
ID:	99594   Click image for larger version
ID:	99595   Click image for larger version
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 2 trips 5 nights
Sagecoachdriver is offline   Reply With Quote
Old 02-14-2016, 03:42 PM   #72
Creativepart's Avatar
Surprised that the flat cable interfered with the signal. I wonder why the connection to the rooftop cable doesn't effect the signal at all. Sure happy it doesn't.
I understand wanting to have the option to position the SAT Dish wherever it will work best. Believe me I do. But I'm loving mine mounted on the roof. I put it way forward on the roof and I just need a spot with no low hanging trees directly in front of my RV.
PS. I put it far forward to be sure that the Fantastic fan cover wouldn't interfere with the view to the SATs if they were directly behind my RV. The instructions say to mount 2' to 3' in front of an 18" high object. Kind of wish I bought a black Dish though.
2015 Forester 3051S
TOAD: 2016 Lincoln MKX
Creativepart is offline   Reply With Quote
Old 02-14-2016, 04:29 PM   #73
My connection cable for sat is right in front my living-room fantastic fan across from the OTA TV antenna. Boy, that TV antenna is sure going to be a tree branch catcher. I had the old batwing crank up on my Winnebago ripped off as we were heading down our street going to Yosemite. Never had a problem before that. Were able to pick up another at CW in Bakersfield and replaced it at the CG. But this one looks expensive and would probably do some roof damage if ripped off.
Back to the roof mount. is yours centered? Hard to tell in photo as you have and I see you have Eternal bond tape holding down coax. You said it's far forward, is that a skylight?
Old 02-14-2016, 04:36 PM   #74
Yes, it's centered side to side. My connection to the SAT cable is in the same spot. Directly in front of the middle vent (a non-powered vent) directly across from the King Jack TV antenna. There are 4 vents - Forward Living area (fantastic fan), middle of the coach just in front of the kitchen (just a vent), the bathroom (powered fan) and the bedroom (just a vent).
I've already broken one of those antenna's on the day I drove the RV home. It hit a branch in my driveway and went flying.
I was able to cover the hole and order a few replacement parts at a cost around $25 and rebuild mine. But honestly, it doesn't work very well. Even in Tucson there were some local stations it couldn't pick up. I wish I had the crank up antenna. I'm sure the extra height would have solved that problem.
It's one of the reasons I didn't save $100 and buy the King SAT Dish.
2015 Forester 3051S
Old 02-14-2016, 04:55 PM   #75
We are always encountering tree branches and I don't always see them in time to avoid them. Did a check and found the King Jack antenna for $112, that's less than I thought it would be. Where did you find replacement parts?
Old 02-14-2016, 05:21 PM   #76
I called King - they sent them out free of charge. Just $26 for the parts.
2015 Forester 3051S
Old 02-14-2016, 08:43 PM   #77
For Benagi
Ben, I think you asked a while back about how much amp draw there was from using Sat TV. If you look back a few posts here, you'll see in photo it only uses 6.1 amps with my fridge, 2 lights on, Sat receiver and TV on. Yours may be different if you have the double door fridge.
Heading out camping tomorrow in sierras, first time for freezing temps so I'll try to keep track of usage. Don't know if I can get a clear shot at the southern sky to use Sat. Also, I'm going to put temp probes in compartments to see how cold the get with limited furnace use.
Old 02-15-2016, 02:34 AM   #78
benagi's Avatar
Hope you have a safe trip and good time. Look forward to your future posts to see how things are going. Also, thx for the comments on amperage draw.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 02-15-2016, 09:10 AM   #79
CreativePart wrote, Kind of wish I bought a black Dish though.
Have you checked with Winegard, they must have black replacement domes for the dish.
Old 02-15-2016, 09:20 AM   #80
Left Coast
Paint it
Sent from my XT1080 using Tapatalk
Retired....but work part time as a pain in the north end of a south bound donkey.......2010 Rockwood 8280 5er....99 Dodge 2500 turbo Cummins
bob caldwell is online now   Reply With Quote
