Old 02-01-2016, 06:00 PM   #1
Sagecoachdriver's Avatar
Sat and cable connections
I'm sure I asked this before, but can't find it. What's the coax on the plate for? Going to label them!
I see there is a 110v receptacle atop the post next to the TV.
So I could place the Vip211z right under the TV then like Creative Parts has done.
For dry camping, I will then hardwire my 400watt inverter to the batteries and place it under the sofa. Then run an extension cord from the inverter along the floor to the carpeted strip separating the cab from the living room flooring and then up to the receiver.
ID:	98760   Click image for larger version
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 10 trips 32 nights
Sagecoachdriver is offline   Reply With Quote
Old 02-01-2016, 11:47 PM   #2
Creativepart's Avatar
On the three coax connector plate:
Top is the cable tv IN connector
Middle is the SAT IN from the roof
Bottom is a shared tv out to the bedroom/outside tv
The jumper is there to send cable tv to the other tvs (bedroom/outside).
The main tv gets antenna and cable signal from the other plate above this one. If the amplifier is on the tv gets over the air tv if the amp is off the main tv gets its signal from the outside cable connection.
If you are using SAT tv - not on the roof - plug the dish into the outside cable connector. Then remove that short jumper and run a coax from the top connector to the SAT in on the SAT receiver. Then you can send SAT to the other tvs by running a coax from the tv out (RF) on the SAT receiver to that bottom connector. Of course, you'll need to run an HDMI from the SAT receiver to the main tv to get SAT tv there.
When running SAT from the roof you just use that middle connector to run coax to the SAT IN on the receiver.
Put the main tv source on HDMI to watch SAT from the receiver.
There are lots of ways to use both tv source settings and turning the antenna amp on and off to view either SAT or antenna or cable depending on how you connect everything.
Does that make sense?
2017 Winnebago Adventurer 37F
TOAD: 2016 Lincoln MKX
Creativepart is offline   Reply With Quote
Old 02-01-2016, 11:58 PM   #3
Thank you, Thank you, Thank you!
printing this out to save!
Old 02-02-2016, 05:33 AM   #4
bubbles's Avatar
Just a thought. I believe the VIP211Z does not have a coax out port, only HDMI. The VIP211K does have both coax and HDMI output ports. Could be wrong. This may or may not be an issue for your install.
Old 02-02-2016, 08:59 AM   #5
I have a ViP211 - without any "z" or "k". It has component, S-video, coax and HDMI TV outputs. I don't know about the other models. It even has analog audio and Toslink audio outputs as well.
Old 02-02-2016, 11:30 AM   #6
Bubbles, you are correct about only the HDMI on the ViP211z, but not an issue as the TV has that input connection.
I'm looking at the NEW King Tailgater in smaller dark grey color. It's only 13.5Hx18.75Wx17"L and can be used as a portable or mount to roof or ladder. If we buy it, I will start with just using as a portable and store in cabinet when not in use. Since we primarily dry camp in National and State parks, trees become an issue and the portability is a major factor. I will alarm it and it would only be out during use.
Old 02-02-2016, 12:06 PM   #7
Sage, if the "z" doesn't have a coax TV out then you cannot watch SAT TV channels at other TVs in your RV.
I'm not sure if there are any real differences between the King and the Winegard - but the King is $50 cheaper and comes standard with roof mounts which makes it about $100 cheaper than the Winegard.
I went with the Winegard only because I have had good luck with my other Winegard products and didn't know if it would be true with the King model. Sometimes I don't trust a cheaper product will be as good, but that's my issue to deal with.
I know that Dish is really pushing the King dish. So, it must be fine.
As to alarming it???? We've never had any issues in the 4 years we've used a Winegard Carryout.
Old 02-02-2016, 01:37 PM   #8
dicky1243's Avatar
the 211z has input cable jack and output and HDMI all
2006 Gmc
2016 Forestriver Sierra 376 BHOK
Full Timers
Dick,
dicky1243 is offline   Reply With Quote
Old 02-02-2016, 05:49 PM   #9
Creativepart, we aren't big TV watchers. Main TV with sat hookup will work for us.
Measured the rear compartment which has a 14" height at opening. Luckily, the Tailgater is 13.5" in height, it will store easily back there.
Today, I remounted my battery monitor shunt so I can attach the inverter easily with eye loops when I hardwire it in.
Old 02-03-2016, 12:02 AM   #10
benagi's Avatar
Questions. Do the King and Winegard run in 110 or 12 volt ? I do know the receivers run on 110. Also, how do you power these units when 110 is not available and you don't want to run the generator? I would think an inverter. And if so, what size would I need? And one last question. How long can you watch Sat TV on just battery power? Thx.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
