11-23-2014, 08:28 PM
Schwintek slide education
Well I finally have my 3051s back and am making headway to Pittsburgh for VA appt. and Thanksgiving with son.
To start I am going to apologize because this is going to be a long post, but will be worth the read if you own a rv with the schwintek in wall slide system. Most of you know the problems I have had with my 3051s and the issues with the slide. Well Thanks to a group of people I have used my slide now 3 times in last week and no problems. And I feel pretty confident that the issues are gone.
Thanks go out to;
Brian Clemens, Mike Jenakowski, hope I spelled his name right, is the Forest River Warranty manager, MClains RV center, Forth Worth TX, Warranty manager Larry, and Finally MCclain service tech. Luise. MCclains is lucky to have tech of this quality and I made sure his supervisors knew it. It was Lou that got me back on tbe road after only 3 days with EVERY repair completed by him and it is him that educated me on the proper use of Schwintek slides.My 2014 3051S went in with motor 1 not working, showing code for "shorted wiring harness or motor", and my trim being pulled off in front of slide.
When he called me and said rv ready I was suprised and then almost dropped dead when he said the motor was not bad and slide is working properly. Well I know the code by now and was confused.
HERE COMES THE EDUCATION.
He told me that the motor was not bad but that the 2 motors were SO OUT OF SYNC it overamped motor 1 and the controller uses same code as shorted motor.
SO HOW DO IT GET SO OUT OF SYNC???
NUMBER 1 REASON " OPERATOR ERROR" and in my case the trim screws pulling out casing front to go out of alignment.
He asked me how I open and close the slide, and I said " push button until all the way out or in".
He said that is the problem,
The proper way to operate the schwintek slide is;
After slide travels full distance, both out and in , continue to hold down the button and count to 10 then release. This allows the 2 motors to sync to each other. I WAS SHOCKED. NOBODY EVER TOLD ME THAT!!! NOT THE SALESMAN, OR THE DEALER TECH ON WALK THRU, OR AFTER 2 MOTOR REPLACEMENTS, NO TECH BEFORE HIM EVER SAID THAT !!!!!!
I was shocked, mad, and suprised all at the same time. He told me that even though slide is fully out both motors may not of traveled full distance. For instance when slide is out ,and I let go of button immeditly, Motor 1 might be at position 0 but motor 2 might be at position 2. Now when you take slide in motors are traveling differant distances and when slide is in ,and i immediatly let off button , motor 1 may be at 1 motor 2 at position 2 1/2. Everytime slide moves they fall farther apart until one of them is so far it overamps trying to pull its share and slide quits.
He told me over 80% of the slide problems he sees are because owners are NOT BEING EDUCATED ON PROPER USE OF THE SCHWINTEK SLIDE SYSTEM. I tested my slide right there, in work bay, the proper way holding for 10 count and YOU CAN HEAR MOTORS SYNC IF NEEDED.
WOW!!!!. I NEVER KNEW THAT !!
MY hope would be that Brian forwards this to someone in Forest River and makes sure dealer salesmen know how vital proper education of slide use is. I really think that Forest River is payiny out a lot of unneeded warranty money. Also I think someone should.contact MClains and talk to the tech and let him help write up a proper use of schwintek slide paper.
He said he thinks it is one of the best slide systems out there as long as they are operated properly
How much money could Forest River save if say even 70% of schwintek slide warranty claims went away??
I Think a memo should go out to all owners with a step by step operating procedure for proper slide operation. If needed some trai ing time.
ALL Dealers need to be educated and trained. Then when a new owner picks up his rv and gets the walk about they should sign a copy of procedure saying they were properly trained
Just an idea but I can't stand to see warrranty money being wasted because it is a soft cost that gets built into each rv and in turn we. As consumers have to pay more for our rv to cover the cost.
11-23-2014, 08:38 PM
Flagstaff 8528 ckss fiver
2008 Ford f350 dually 4x4 desiel
11-23-2014, 09:21 PM
Canadian Member
Here is a video on syncing the motors from the manufacturer Lippert Components. They say you only need to hold the switch for 3-5 seconds.
11-23-2014, 09:58 PM
Man i have had them sync at 2 count lik3 or 4 and A 7 COUNT. if you hold for 10 then you HAVE FOR SURE EXCEEDED manufacturers time. And for the peace of mind I will give up 7 seconds of my life to make sure the motors have enough time.
11-23-2014, 10:19 PM
Tbe second video is good. The te b pretty mu h said same thing. He said if slide out and not retracting but one motor ok get manpower to close slide thsn open about 3 to 4 in hes then close. Re recommended doing it 5 times not 3 holding switch down cor 10 count each time. This should sync motors and can then open fully. I wish I knew about these videos when I bought rv it may have prevented problems. Seasoned rvers will know but newbies like me had no clue and my dealer was not much help wben first failure occured. They thought lippert and s bwintek 2 totally seperate companies not lippert as parent company. Tbis is where FR could help themselves.
11-23-2014, 11:05 PM
Thank -you MM1VET for this info I also was never told about the things you have said here or what the videos have shown!! Hope all is well with you and travel safe.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
11-23-2014, 11:25 PM
Great info I didn't know. Thank you!
Scizzorman
11-23-2014, 11:31 PM
Always Learning
Great info. I just told my wife since she mostly does the slides.
11-24-2014, 12:03 AM
My dealer never told me that
11-24-2014, 11:02 AM
Never knew this. I always thought if I held the switch after the side was seated it would stress the motors.
My front slide does not work this way since I believe it only has one motor It will continue to run and make a ratcheting sound if the switch is held. I just bump the slide in or out and try to stop it just as it is about to ratchet. Guess I need to research my slide designs.
Thanks for the post
11-24-2014, 11:33 AM
Always Learning
I assume that this is specific to the Lippert Schwintek slides with 2 motors. I have 2 other slides that do the same ratcheting sound- those are single motor designs and you want it slipping as little as possible.
11-24-2014, 01:14 PM
Canadian Member
Each slide mechanism is different. On the ratcheting type on my Roo, there was a single toothed rail under the center of the slideout. I was told to hold the button until it ratchets and then release it. I never had any issues with that slide. I've never had a Schwintek.
11-24-2014, 06:10 PM
I appreciate the information and the clarification that this is not for all slides. I have only one small one and it makes the ratchet noise if I leave the switch depressed for too long. Based on what I read here for these slides (single motor?) We are not to follow the same instructions as outlined very thoroughly for the longer two motor slides.
Many thanks to all of you.
11-24-2014, 06:20 PM
Always Learning
Correct. Single motor and you shouldn't follow these instructions.
11-24-2014, 06:37 PM
Thanks again, you all teach me a lot everyday!
11-24-2014, 08:20 PM
Always Learning
I'm in the same boat! I still have questions every day and turn to the fine folks here.
11-24-2014, 08:37 PM
Did not know this. Very good info. Thanks
Sent from my SM-G900V using Tapatalk
Jim and Carol
2012 Crusader 290RLT
2010 Ford F-250 King Cab Diesel
Harley Davidson Edition
11-24-2014, 09:22 PM
You all are very welcome and I just thought this would be a.great.place to help fellow rvers and give back for all the help people have given us since we went fulltime. In every one of the probably 20 parks we have stayed in since July someone ALWAYS offers tips or help. Rvers are a great group of people.
12-01-2014, 08:26 PM
So we just bought a 2015 3051 and no one suggested anything like this to us. This forum is extremely interesting and helps us newbies.
