Old 07-09-2019, 04:44 PM   #1
Sewer Hose Sunseeker 2019 3050S
I love the fancy WasteMaster sewer hose with the fancy coupler on the end of the hose and the fancy drain hookup with a shutoff lever on the other end. Sadly, my hose ripped on an exposed fastener inside the tank access compartment, after which I found out how much those fancy hoses are worth ($118).
Can you take the fancy ends off the hose and just couple them to a cheap replacement hose? I tried to get them off, but didn't want to force them.
Mark Haffner
2019 Sunseeker 3050 SE
(30' with one long slideout, Ford E450 chassis)
Parkfreeon6th is offline   Reply With Quote
Old 07-09-2019, 05:31 PM   #2
They are removable but I doubt that they will fit any other style hose. You can purchase a camlock to bayonet adapter that will allow you to attach a bayonet style sewer hose.
Personally I like the WasteMaster system and would spend the $ to replace. But there are other options.
2017.5 Forester 3051S
2019 Jeep Trailhawk toad
Steve-W is offline   Reply With Quote
Old 07-09-2019, 05:34 PM   #3
SeaDog's Avatar
The cost does not always garuntee the quality. my cheap sewer hose has worked for years and cost me 29.00 dollars. I looked at the hose you are talking about and form the looks of it you should be able to just cut the hose by the fittings and put new fittings on.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
305, 3050s, sunseeker
