Old 08-29-2018, 10:58 PM   #1
shchef
I have a 2017 forester 30 ft I cannot find the were to check hydraulic jack fluid
any help
shchef is offline   Reply With Quote
Old 08-29-2018, 11:32 PM   #2
Duckogram's Avatar
The more info you provide the better the answers you will get.
First place to look is on the inside of the chassis frame rail. There are a few different brands and the exact location will require the model of your 2017 Forester (The only 30’er is the GTS 2801QSF) and the brand of leveling system you have. A photo of the control panel will answer that question.
So get the old bedspread out and crawl under the drivers side in the middle.
Edit: Just saw where you are. I’ll be in Buxton on the 13th.
ILB ( | )
Old 08-30-2018, 02:36 PM   #3
it is 3051s
i will crawl under and see
thanks
