Old 02-09-2016, 11:49 PM   #1
Shore power at home
Hi guys I am getting my brand new 3011 ready for our first trip. I plugged the RV into my shore power at home and nothing is working other than to clock on the microwave. No interior lights nothing any ideas? Thanks in advance.
Japerico is offline   Reply With Quote
Old 02-10-2016, 12:06 AM   #2
Creativepart's Avatar
Check the battery disconnect switch. It's probably in the off position.
2017 Winnebago Adventurer 37F
TOAD: 2016 Lincoln MKX
Creativepart is offline   Reply With Quote
Old 02-10-2016, 12:08 AM   #3
Briorick's Avatar
You are getting power to the Microwave, have you checked your Converter to make sure all the breakers are switched in the "ON" position. This would be a good start. It's possible they were switched off without your knowledge.
Rick & Brian
1 Happy Camper Pup ( Mya )
2017 Salem Cruise Lite 232RBXL
2004 GMC Sierra 2500HD LT 4x4 6.0 / 4:10
The best plans can be of those that happen in the spur of the moment!
Briorick is offline   Reply With Quote
Old 02-10-2016, 12:12 AM   #4
When I turn the battery switch to the on position everything works. But isn't that draining the batteries and not working off of power from the house? With my old RV I would just plug it into the house power and leave the battery switch in the off position and everything would work.
Old 02-10-2016, 12:18 AM   #5
HopHed's Avatar
It will not drain the batteries as they are being charged while plugged in by the converter/charger which runs your 12v system such as lights etc.
1978 Ford Rollalong
2004 Fleetwood Tioga 29V
2016 Forester 2861DS (11-13-15)
HopHed is offline   Reply With Quote
Old 02-10-2016, 12:21 AM   #6
Briorick's Avatar
Sorry, can't help on this one. I have never dealt with a Battery Cut Off switch. Like you, I have always just plugged them in to Shore Power and Presto..... Have POWER.
I'm going to watch this post, and hopefully learn something NEW myself.
Rick & Brian
Old 02-10-2016, 12:27 AM   #7
Briorick's Avatar
Hophed, I have a question for you. If a person has these battery cut-offs and were to remove the battery from the unit, say when storing, will the Shore Power still not work when plugged into it?
I have no clue when it comes to Battery Cut-offs. Now is the time to learn.
Rick & Brian
Old 02-10-2016, 12:29 AM   #8
Just to make sure I am understanding this. Whenever I am using the RV on any sort of shore power house/camp ground I need to have the battery cut off switch in the on position for things to work frig, lights,microwave and this will not drain my batteries?
Old 02-10-2016, 12:32 AM   #9
HopHed's Avatar
Not 100% sure but I believe you need the batteries to run the 12v system and the converter/charger lowers the voltage from 110v to charge the batteries. Once fully charged the charger will change to a trickle charge.
1978 Ford Rollalong
Old 02-10-2016, 12:34 AM   #10
HopHed's Avatar
The frig and microwave is 110v and should run with the switch off. Lights and anything 12v will need the switch on.
1978 Ford Rollalong
power
