08-07-2010, 10:14 AM
Shower drains in black tank
I own a 2004 Lexington 27s model. When the black water tank is full, if you take a shower, the water does not drain from the shower. If you flush the toilet, green water comes up the shower drain.
Is it possible that the shower drain is connected to the black water tank, instead of the gray water tank ?
Thank you for any information on this matter.
08-07-2010, 01:21 PM
Welcome to the forums.
Showers should NEVER be connected to the black water tank. My guess would be that when you dumped your tanks the last time you didn't get the valves completely closed and you are getting cross over from one tank to the other.
You can make sure the shower is draining to the grey tank too with a little test. Make sure you have fully dumped all your tanks. Make sure the black water (sewer) valve is closed. Open the grey tank valve and make sure the cap is off the pipe. Turn on the shower. Water should run from the pipe.
Good luck...
08-07-2010, 01:52 PM
Our 2011 Rockwood shower drains into the black water tank. I guess Forest River was to cheap to run an extra 24" of pipe to the gray tank. We have to empty the black tank every couple of days. When I get Back home this fall I am going to plumb the shower to the gray tank
2011 Rockwood 2902SS
Days camped in 2009: 35
Days camped in 2010: 150 plus
Days camped in 2011: 162
08-07-2010, 05:18 PM
Your shower should never empty into the black water tank. If you do overflow the tanks raw sewage will back up into the shower. This is a health issue.
08-07-2010, 05:28 PM
I have a list a mile long for Forest River to fix this fall, somehow I don't think they will re-plumb the shower to the gray water tank. I will have to do this myself.
08-07-2010, 06:22 PM
5th wheeling since 1991
I just don't believe FR would hookup the shower to the black water tank.
2011 Rockwood Sig. Ultra Lite 8285WS by Forest River 2011 - 9 Trips / 66 Days Camping / 7,080 Miles 2012 Planned so far 35 days / 4,000 miles 2011 F-250, 6.2L Gas
08-07-2010, 08:52 PM
I am 100% sure that they hooked up the shower to the black water tank. I did a quick test after our first trip (did not have time to pull down under belly) I opened the black water tank then ran the tub and water came out of black water tank. This fall it goes back to the dealer (or factory) for repairs, if things are not fixed correctly then we will look at other options.One of them being selling the unit, we actually were in Conway NH this week looking at Carriage Fifth wheel units. Forest River Really dropped the ball (again) on the 2011 Rockwood.
08-07-2010, 09:03 PM
Maybe I should obtain a copy of RVIA ANSI/NFPA 1192, which is the standard that Forest River is suppose to build to.
08-08-2010, 07:48 PM
I thank you for the information. I will do further tests to find out where the shower drain is hooked up to.
08-08-2010, 11:45 PM
Moderator
Now for the rest of the test, with the tanks dumped, you said you ran the shower and it came out of the black tank. Now flush the toilet and see if it comes out of the black tank also. May sound stupid, but I'm a long ways away, and have to ask you to check everything.
I like my Forrest River product, and wish them no harm, but if is as you say, and you must be certain, there is one "H##LL of a lawsuit looming because you can dump gray water on the ground, meaning shower water, in a lot of places.Dumping Black water is never legal, as far as I know. Let us know if the toilet dumps out of the same valve as the shower, good info to have.
Windrider,
Too many toys, not enough time.
2001 F150 SuperCrew
2002 Jeep Wrangler
1978 Cessna 152
2000 Honda 750 Nighthawk
2008 Work and Play 18LT
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 395 |
| 59 members and 336 guests |
| acadianbob, autorot8, BelgianSquiggy, Brockly71, brookside, bts001, buzzmonster, campfirefun, caper, capndinghy, Char_n_Kath, Deputyseven, donn, Elanpottery, Emptypockets, Forbes, Fourn3833, freedom 750, GaryRudolph, grhodes50, halliday, herk7769, Iggy, imabmwnut, itech, JDWeir, Jeep4Two, jk510, JoeyO, jsutherl, katsmeow62, kenson, Laura, leencharlotte, Linnemj, mckirby50, mstell2, Newellri, peaeye, RayJae, RED Baron, reliefman, rerger, ripwild, rkswyo, Rod Johnson, rstoro, Shelley4832, shooted, slipf18, Sockman, Steve7575, stevos, Terier, tucket, wayne anthony, WestCoastRV'er, Wildwood Danny, wvcampers |
| Most users ever online was 881, 06-22-2011 at 11:07 AM. |
