Old 08-11-2018, 04:42 PM   #1
Shower Faucet Replacement
I want to replace the shower faucet on my 2012 3011 DS. Has anyone replaced their factory shower faucet with a better quality unit and if so, how did you access the back? There's a screwable escutcheon below the faucet but there's no way to get your hand up to the back.
I've already upgraded the kitchen and bath faucets to brushed nickel and what a change
Mach428 is offline   Reply With Quote
Old 08-12-2018, 09:33 PM   #2
Garrette's Avatar
My faucet is accessed through an access panel in the back of a shallow cabinet on an interior wall.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 08-13-2018, 01:06 PM   #3
RETIRED AND LOVING IT
n-e-d's Avatar
yup, thats your shower valve access point. Mine (Sunseeker 2650s)was on the bedroom wall back of the shower wall. Was a tight fit to into mine but supply nuts and valve nuts were just hand tight no tools needed
Mary and Me
2015 2650s "Finally"
2015 Jeep Cherokee
2016 Ford Race Car Red 350HD Diesel Cargo Van HR DRW EXT DIY Daytripper "Red Roamer"
n-e-d is offline   Reply With Quote
Old 08-13-2018, 02:12 PM   #4
There's no access panel on the bedroom wall / behind the shower faucet on my 3011
Old 08-26-2018, 06:02 PM   #5
Today I needed access to my shower connections (I had a previous leak problem). I'm sorry that the picture I have is not showing the proper view. The top is the left side, the bottom is where you see the round shower screw on plate. Tilt your head to the left to see it correctly.
I cut a 10" x 10" hole with a box cutter. the plywood is very thin and it was easy to cut a perfect square. I am making a very thin picture frame around the cut out piece and will screw it back in the hole. It will look like a professional access panel when I'm done.
You can see that the plumbing fittings are the same as house fittings and they screw on from the bottom. your new shower faucet will need the same set up.
I HOPE THIS HELPS
Hailey is offline   Reply With Quote
Old 08-27-2018, 05:21 AM   #6
Excellent. Thank you very much for the idea!
faucet, forester, replacement, show, shower
