Old 08-02-2015, 03:51 PM   #1
Citrus County, Fl.
GL1800Rider's Avatar
Side Cameras Foggy
The cameras worked fine when we picked our 3011 up from the dealer in mid June but I noticed when I took it to the tire shop to get one of the tire valve extensions tightened that the left and right cameras were foggy. We finally left on our first trip this past Friday and initially they were fine but shortly after they fogged up and got worse as we completed our 135 mile ride. The right camera appeared to have curved droplets on it. No rain but of course we have high humidity here in Florida so that may be a factor. Has anyone else experienced this?
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 08-02-2015, 08:54 PM   #2
papap's Avatar
Mine looks the same. But notice it's the sun that makes it look that way. When I turn a different direction it's clear.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 08-02-2015, 09:21 PM   #3
Boso's Avatar
Had both of mine replaced now have bright glare I think reflecting off the white sides of coach better view if clouds pass over. I only realized this the other day while at the repair shop hopeful there is some remedy but not likely
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 08-02-2015, 09:36 PM   #4
ramair's Avatar
I have had this happen a couple times with the right camera and its from the A/C running the water will drip from the roof and sometimes it drops onto the camera cover and then moisture gets inside and that what gives you the fog for a while but with mine it will clear itself up after a while.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 08-02-2015, 10:22 PM   #5
Boso's Avatar
This comment is for Ramair .I thought the same thing my housing would be full of water after a rain even could see what looked to be water moving on side cameras I was informed by Velvac and Forest River the camera lenses are sealed and waterproof I installed the new cameras on mine so I understand what they mean now a little better.The housing just holds the lens in place it has a Click image for larger version
Name:	ImageUploadedByForest River Forums1438572111.145144.jpg
ID:	84821weep hole in bottom corner two Allen screws holds it on.The wire plugs in mirror arm so I'm not sure what causes the cameras to do that but I sent my old ones in so they could test
Old 11-09-2015, 08:42 AM   #6
I have this problem all of the time. how did you fix the problem?
kkopperl is offline   Reply With Quote
Old 11-09-2015, 09:07 AM   #7
MarsMan's Avatar
I put a piece of flat black tape along side of it to reduce glare and it appears to have helped
MarsMan
2015 Coachmen Prism 24J MBS
USN-R '01-present
MarsMan is offline   Reply With Quote
Old 11-09-2015, 09:57 AM   #8
Citrus County, Fl.
I still have the problem but on our last trip (1000 miles) it was a bit better. They always start out crystal clear but end up fogging or water droplets after about 30 minutes or so of driving. We have full body paint so I don't think the reflection off of the white is an issue. I has been reported to the dealer but from what I have read on here I don't think replacing the cameras will help much. Rear camera is perfect with the exception of no sound and that camera has been replaced.
99 Terry 31G
Old 11-09-2015, 10:49 AM   #9
Boso's Avatar
Cameras on last trip pic in the shop now cameras on list once againClick image for larger version
Name:	ImageUploadedByForest River Forums1447084177.912707.jpg
