Old 08-06-2014, 12:03 PM   #1
Unhappy Slide drive and driven gear issue
Question for bclemens? On the top driven gear of wall slide the last two teeth have been ground in half by the drive motor gear, would this cause the slide to open up on its own while driveing down the road. I still can't work out how to post pics yet or i would show you what I mean HAHA! Best way to discribe is if you look at the gear think of it beening cut top to bottom in half.Its only on the top long gear which is attached to slide.Any help would be great thanks
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 08-07-2014, 11:08 AM   #2
GM
bclemens's Avatar
I don't think it would let the slide move out on its own. There is still the other side of the slide and the bottom track. When you say "gear" I assume you mean the machined "worm-rail" (that is the aluminum track that sits top and bottom of both sides).
To post a picture, to the right of the "Post Quick reply" hit "Go Advanced" instead. That will give you options to upload a picture.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 08-07-2014, 11:55 PM   #3
will post pic and I do mean the worm rail. The slide came out about a half inch only on the end of the wrecked rail while driving on some rough roads.
2014 Forester 3051s
2012 Sonic toad
Old 08-12-2014, 08:06 PM   #4
slide gear
Name:	rv problems 005.jpg
Name:	rv problems 006.jpg
ID:	60379 bclemens here are the pics of my slide gear problem which I asked if it would cause walk out of slide
2014 Forester 3051s
2012 Sonic toad
Old 08-13-2014, 08:01 AM   #5
GM
bclemens's Avatar
Document and maybe put a call into the dealer just to be safe.
Old 09-03-2014, 05:02 PM   #6
bclemens just a follow up on slide gear issue, dealer called today and said they will replace slide gear under warranty. Also they want to look at what may have caused this problem.
2014 Forester 3051s
2012 Sonic toad
slide
