Old 06-04-2015, 08:59 AM   #1
Slide gear replacement.
This is for Crockett, My 3051s is going in for the front slide gear tower replacement , is this a BIG? job to do and what should I look for that it is done correct? Thanks in advance.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 06-04-2015, 05:04 PM   #2
What was the symptoms of this failure. Mine is making weird noises.
13larry is offline   Reply With Quote
Old 06-04-2015, 05:30 PM   #3
Wasn't noise its the teeth on the gear track are sheered in half, lap top is acting up will try to post pics
2014 Forester 3051s
2012 Sonic toad
Old 06-04-2015, 05:33 PM   #4
See if this works
Name:	rv problems 006.jpg
2014 Forester 3051s
2012 Sonic toad
Old 06-05-2015, 01:08 PM   #5
Just had front and back replaced on my 2014 3051s. Dealer did an outstanding job and wholesale warranties along with Jeff from Wholesale took care of everything promptly. My slide seals properly now. Same problem lower gear with messed up teeth. CJ at barryland handled service perfectly! I know these guys get a lot of bad rap sometimes but this was my first trip to the dealer and my first warranty claim.
lmouhot is offline   Reply With Quote
Old 06-05-2015, 01:28 PM   #6
Stormrider151's Avatar
I'm a little concerned about this myself. I have two slide and on the main slide I here a noise sometimes like the gears maybe slipping a popping noise. I have some other warranty work that needs to be done and this is on the list.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 06-05-2015, 02:08 PM   #7
Did the dealer give any idea of what caused the gear mess? Do you know how it was repaired ( do they have to remove slide)?
2014 Forester 3051s
2012 Sonic toad
Old 06-12-2015, 07:40 PM   #8
Sorry for the delay. You cant get alot of information but did get to see the old slides on the ground. The trim piece on my full body paint is white but you only see that when slide is out. Works like a charm anyway just think something may have been wrong from the factory
Old 06-14-2015, 07:10 PM   #9
Bump.
2014 Forester 3051s
2012 Sonic toad
Old 06-19-2015, 03:09 PM   #10
June 19th,2015, took MH into dealer today for the slide gear tower replacement and to replace the skylight they destroyed, Service guy said they are going to put best repairman on job and should have done in a week. Lets see how they do , been waiting since Sept 2014 for this to be completed.
2014 Forester 3051s
2012 Sonic toad
Old 06-19-2015, 03:29 PM   #11
ourflat's Avatar
That is Exactly why I went with Wholesale Warranties! Great to hear...
Frank
KM4FVI
Frank
2016 Days Camping so Far: 24
2013 3051S Forester
2013 Elantra GT (Toad)
WashU EMBA "39
ourflat is offline   Reply With Quote
Old 06-19-2015, 04:42 PM   #12
Boso's Avatar
Is forest river paying the bill for these problems or are you having to pay or use extended warranty just curious I'm sure mine will go out on me but after my year is up
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 06-19-2015, 04:49 PM   #13
ourflat's Avatar
I'm certain FR would come to the table to repair the slide if the problem was within the 12-months of ownership but for those of us affected outside the warranty it will be left up to our own resources to have it repaired! Hence my ESP with WW!
Frank
KM4FVI
Frank
2013 3051S Forester
WashU EMBA "39
Old 06-19-2015, 06:08 PM   #14
Good luck on their 'best repairman.' Hope he isn't like ours who put the Fantastic vents on backwards!! Seriously, this has been a nightmare for you and really hope it gets rectified!
SkipnTerri is offline   Reply With Quote
Old 06-19-2015, 07:23 PM   #15
Hey Boso and Ourflat I am well out of my one year, but FR is footing the bill for the repair, I have to give a big hats off to them for that.This isn't the first problem I have had with the slide and it has been all been recorded with the factory. I also have extended warranty just in case this happens again , (Lord I hope not!!!) but it may not be covered in the FINE PRINT.
2014 Forester 3051s
2012 Sonic toad
Old 06-19-2015, 07:24 PM   #16
Thanks Skip, will keep you posted
2014 Forester 3051s
2012 Sonic toad
Old 06-19-2015, 08:26 PM   #17
Anything that's rermotely considered linkage is not covered by extended warranty.
poppytoymaker is offline   Reply With Quote
Old 06-19-2015, 08:39 PM   #18
ourflat's Avatar
Linkage?
Frank
KM4FVI
Frank
2013 3051S Forester
WashU EMBA "39
Old 06-19-2015, 09:04 PM   #19
Boso's Avatar
I wouldn't think slide motors rail teeth or rollers would be considered linkage that's where the problems lie imo
Old 06-20-2015, 11:21 AM   #20
Just reread the warranty pamphlet and it states slide drive mechanical assembly is covered
2014 Forester 3051s
2012 Sonic toad
replacement, slide
