Old 09-14-2013, 11:48 AM   #1
DnL
Slide Out Motors
Can anyone tell me where the slide out motors are on a Forester 3011DS? And is that where the manual retraction operation is?
Thanks in advance for your help.
DnL is offline   Reply With Quote
Old 09-16-2013, 08:37 AM   #2
GM
bclemens's Avatar
Living room is a below floor Lippert slide. Manual retraction is below the unit. Should be a shaft point down in the roof of one of the compartments.
Bedroom is a Lippert In-Wall slide. Motors are at the top. If you search there are several references and links to videos on how to retract them. You can also check youtube.com for the Lippert videos.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 09-16-2013, 11:46 AM   #3
DnL
Thank you very much. This is exactly what I needed.
Old 09-17-2013, 10:31 AM   #4
Lippert - Schwintek In-Wall Slideout VIDEO!!
Tim
2013 Forester #3051SF
2009 Toyoda Tacoma (toad)
2010 Newmar Dutchstar (Sold)
2011 Fleetwood Bounder (Sold)
trwmodela is offline   Reply With Quote
Old 09-17-2013, 01:36 PM   #5
DnL
trwmodela,
Thanks for the video. Now I just have to figure out where the circuit board is located. There must be an access panel somewhere.
Old 09-17-2013, 01:44 PM   #6
Mine is under the cabinet that houses the 3 burner cooktop. There is a panel with four small screws. Yours maybe different because mine is a #3051S single full slide.
Tim
Old 09-17-2013, 08:44 PM   #7
Tim,
Excellent video, thanks for posting!
Damon
BiffF15 is offline   Reply With Quote
Old 09-18-2013, 08:05 AM   #8
On my 3011 the Circuit board for the Bedroom slide is mounted under the bed.
DennyH is offline   Reply With Quote
Old 09-18-2013, 09:15 AM   #9
It is an easy system to understand and override. I helped someone a year ago push his slide in after releasing the two motors located at the top. But one great feature is the safety device. It stops when something restricts movement. Some Class "A"s don't have this, neither did my Newmar Dutchstar.
Tim
Old 09-18-2013, 10:00 AM   #10
Denver, CO
garbonz's Avatar
Originally Posted by DnL View Post
trwmodela,
Mine is behind the panel at the front of the pass through storage. I stumbled on it running my inverter wiring, I could be anywhere they decided to screw it and not necessarily in the same place as other units.
Time to go on an recon mission.
2017 Fuse 23T
slide, slide out
