Old 09-25-2015, 05:38 PM   #11
Originally Posted by Freedbyjc View Post
Looks like the full side slide on my 2015 3051S is slipping loose near the driver's door. I've got an appointment next Tuesday at a local FR dealer to check it ( Yes, I did tighten all the screws AFTER I took the picture), and a slide sync issue (uneven when it retracts... resynced several times, still out of phase).
Anybody else have this happen to them?
Is this what your's looked like?
Name:	slide problems 003.jpg
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 09-25-2015, 11:28 PM   #12
If you call coach net they can let you talk to a tech or schedule one to come to you. Or call Forest River customer service and they may be able to walk you through it.
As you absolutely surrender to His will…May you be absolutely overwhelmed by His love,
FreedbyJC
Freedbyjc is offline   Reply With Quote
Old 09-26-2015, 03:45 PM   #13
Thanks for the suggestion but mine has been fixed ( thats what it looked like before repair) in the end I had to have the complete front slide gear tower ( thats what is coming away from the body) replaced , thankfully it was done under warranty. Good luck with yours
2014 Forester 3051s
2012 Sonic toad
Old 09-27-2015, 12:16 AM   #14
Our was at the top. Forest River told us too call a dealer ASAP and they will add support brackets at no charge to us.
FreedbyJC
Old 09-27-2015, 01:37 AM   #15
JimOneil43's Avatar
What I'm curious about and have never gotten an answer to is: has FR ever made any product improvements to correct this problem in future production?
Joshua or Brian ????
Retired and loving it...Can't wait to get back on the road!
2017 Forester 3051S ("Farley")
Born April 18, 2016
Toad: 2014 Honda CR-V AWD
GO DUCKS !!
Jim & Diana (and 3 cats)
JimOneil43 is offline   Reply With Quote
Old 09-27-2015, 10:17 AM   #16
I'm thinking that's why they told me too have the slide support ordered and installed... my 2015 3051s doesn't have them but the 2016 does and others will.
FreedbyJC
Old 09-27-2015, 10:37 AM   #17
Do you have more info on these slide supports your talking about? Where are they installed and to what?? Have not heard about this. Thanks
2014 Forester 3051s
2012 Sonic toad
Old 09-27-2015, 01:30 PM   #18
JimOneil43's Avatar
Have not heard about any supports either. Would like to hear the full story and if they are now standard on 3050/3051.
Born April 18, 2016
GO DUCKS !!
Old 09-27-2015, 04:32 PM   #19
Creativepart's Avatar
Your photo got me thinking about my slide. So I checked and no, it wasn't coming off of the wall of the RV like your photo - but there was one screw sticking way out. I tightened it and sure enough EVERY SINGLE SCREW was a little loose and needed tightening. And, this was on both ends of the single slide on the 3051.
I'm sure glad I saw your post.
Check your slide folks.
2017 Winnebago Adventurer 37F
TOAD: 2016 Lincoln MKX
Creativepart is offline   Reply With Quote
slide
