Old 09-08-2015, 08:18 PM   #1
Slide slipping???
Looks like the full side slide on my 2015 3051S is slipping loose near the driver's door. I've got an appointment next Tuesday at a local FR dealer to check it ( Yes, I did tighten all the screws AFTER I took the picture), and a slide sync issue (uneven when it retracts... resynced several times, still out of phase).
Anybody else have this happen to them?
As you absolutely surrender to His will…May you be absolutely overwhelmed by His love,
FreedbyJC
Freedbyjc is offline   Reply With Quote
Old 09-13-2015, 07:25 PM   #2
How quiet is it during operation? My opening was not cut the correct size at the factory. The top was about 1/2 inch too wide. This caused the track to go bad. It started skipping and clunking. The dealer installed all new tracks and added a wooden shim. The new mech works great. You can see if yours is the same with the slide in, by looking inside at the opening and seeing how close it is to the slide wall. I have found the screws do not come loose when the slide works correctly.
13larry is offline   Reply With Quote
Old 09-13-2015, 07:38 PM   #3
The slide is quiet, the front motor runs a few seconds longer after the rear one stops. We tried the whole resync procedure three times and it would not sync up. Dealer will look at it Tuesday.
FreedbyJC
Old 09-13-2015, 07:43 PM   #4
Is there something stopping the rear early? I believe either end will stop when the current gets too high. Look and see if there is something on the floor in the rear.
Old 09-13-2015, 07:46 PM   #5
Nope, nothing stopping it.
FreedbyJC
Old 09-25-2015, 03:08 PM   #6
How do you re sync a slide
oakie47p is offline   Reply With Quote
Old 09-25-2015, 03:11 PM   #7
FreedbyJC
Old 09-25-2015, 03:11 PM   #8
We are having problems with our bedroom slide have to just edge a little 2 in 1 out..any idea how to fix it,our dealer is 6 hrs away
Old 09-25-2015, 03:11 PM   #9
Thanks a lot
Old 09-25-2015, 03:48 PM   #10
Okay,that didn't work. We did notice before that there was a red light on under the bed,not sure what that means? Any ideas?
slide
