10-21-2014, 06:47 PM
Slideout maintenance
Do the slideout tracks need occasional lubrication? What about the seals - do they need Armor All treatment?
10-21-2014, 07:30 PM
Yes, and yes. I use a dry lubricant spray for the tracks and Armor All for the seals. They make seal conditioner for them, but I'm pretty sure it's exactly the same thing. The seals are just rubber weather strip type stuff. Twice a year is generally recommended at minimum.
10-21-2014, 07:46 PM
You need to spray dry lube on your gears and shaft atleast 2 or 3 x's per year (Napa) also do your seals both inside and out. Do not use anything on the slide seals except 3 things that will work #303 lube, slide lube, or just plain " baby powder". Some people swear by it, I have never tried it. DO NOT USE ARMOR ALL. There is a chemical in the liquid that is bad for the seals. But that is just my opinion...Happy Camping...
Coachmen M/H
Concord
2018 / 300 DSC
10-21-2014, 08:04 PM
Thanks guys!
10-21-2014, 08:15 PM
I prolly messed up my tracks on my slides....before I was educated on lubes...I greased the crap outa my slide tracks. I guess time will tell. :-((
2017 Puma 297RLSS
10-21-2014, 09:02 PM
By 303 Lube, do you mean Aerospace 303 Protectant? Same stuff many recommend for protecting decals and some say on the tires.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
10-22-2014, 05:48 AM
How does one grease the seals on top of the slide? Mine has canopies that would seem to prevent this.
10-22-2014, 06:03 AM
Yes that is the product, IMO the best stuff on the market... PS: works great on tires, Has a UV protector in it.
Coachmen M/H
Concord
2018 / 300 DSC
10-22-2014, 06:15 AM
If you mean slide toppers, it is a little harder. They have a new foam spray for slide out rubber. I just shoot it on half from one side and then half from the other side. You do not have to wipe it in. on the inside I just start to bring the slide in until the rubber starts to flip over. Then go on the outside and just run your hand down them pushing them in on the sides. Then spray the rubber, the top seal is a little harder. DO NOT FORGET THE SWEEP AT THE BOTTOM. I just open the slide and pull down the rubber buy hand and lube the inside then lube the outside. That's a important one, it stops water from entering from the wet roads.
Coachmen M/H
Concord
2018 / 300 DSC
10-22-2014, 06:29 AM
The lube my dealers part manager sold me is for slide seals and it sprays out a couple of feet in a foam that quickly drys
I get up on a ladder and reach in and spray from both sides
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
10-22-2014, 06:53 AM
To answer the original post
Dealer sold me two products
The foam lube for seals mentioned above
An anti corrosion spray that comes out thick like spray grease and drys a light brown color that is used on gears and tracks
I'll get the name of the products they are in the unit at the dealer for other service
'78.....tents
10-22-2014, 07:24 AM
Is there any brand of slide lube that works any better than another? Looking on amazon there are quite a few CRC, Liquid Wrench, PB Blaster, Camco, 3M, Thetford, Blue Works the list goes on or all they all about the same.
2021 Alpine 3790FK
2021 F-350 SD XLT PS 6.7 Dually Longbed 4wd Crew Cab
10-22-2014, 07:42 AM
The best dry lube spray that I have found is graphite gray for your gears or CRC lithium white would be my second choice. You can't put any grease type or liquid due to it will attract dirt and then you could brake a gear tooth. Has to be a dry lube. I think the graphite works the best but cost the most per can but will last longer and seems to me makes a smoother ride when extending or retracting. the spray foam as mentioned above is good stuff for the rubber, I don't like the gear lube that RV stores sell. But that is just me and my own opinion.
Coachmen M/H
Concord
2018 / 300 DSC
10-22-2014, 08:14 AM
I figured I would get the 303 for the seals and I can use it on other stuff can get a gallon of it for $40 off amazon Amazon.com: 303 (30320) Aerospace Protectant - 1 Gallon: Automotive and this for the slide gears CRC Dry Graphite Lube, 10 oz Aerosol Can, Black: Power Tool Lubricants: Amazon.com: Industrial & Scientific
2021 Alpine 3790FK
10-22-2014, 11:56 AM
That is perfect for your unit, make sure you lube that sprocket and all 4 sides of the ram. That's cheap for a gal. of 303, that stuff works great. They were selling it at the Goshen Rally for 50.00. Last time I bought a gal. it was $65.00. They must have seen me coming.....
Coachmen M/H
Concord
2018 / 300 DSC
