Old 07-23-2019, 10:35 PM   #1
Bonjoey's Avatar
Slideout rattle
Our sunseeker 2650s has 1 slideout and it does rattle when driving slow and/or bumps. I have tried from silicone lube, putting foam under and in the dinette and I even bought a small slide lock to go front-back and it still does it. Cant trace it, cant replicate it. Its coming from driver side back seat. I dont want to buy another slidelock to go side-to-side without knowing if that would stop it.
Im stumped. Any ideas?
2019 FR Sunseeker 2650S E450SD
Bonjoey is offline   Reply With Quote
Old 07-24-2019, 08:47 PM   #2
Usually Confused Member
emm-dee's Avatar
Not sure what you mean by putting foam under and in the dinette. We had a rattling sound coming from the dinette area which was completely solved by lowering the dinette table. No foam, etc. just putting it in sleeping position.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
emm-dee is online now   Reply With Quote
Old 07-24-2019, 09:07 PM   #3
Bonjoey's Avatar
Sorry, what I meant was i put foam under the slides “C” metal thingy and foam in the dinette seats and anywhere I thought the sounds coming from but no luck.
Can a schwintek slide motor became loose and makes a rattle sound?
Old 07-24-2019, 09:24 PM   #4
I would think if a slide motor was loose enough to rattle the slide wouldn't work. Is this a u shaped dinet or a two seater? I would look at the table as the previous post suggested.
tlf65 is offline   Reply With Quote
Old 07-24-2019, 09:26 PM   #5
Bonjoey's Avatar
Yeah the slide operates/sync properly. It’s a 2 seater (or 4?) dinette.
It is not the table, i fixed the table and that one squeaks when loose.
Old 07-29-2019, 04:01 PM   #6
Bonjoey's Avatar
Had a chance to take a look at this yesterday while DW driving it. Is it normal for a slide to move while driving? I noticed the bottom part will push out maybe 1/8” and if I press the slide “in” it will move back (of course can only do this while parked). I also noticed the sound is coming from the roller underneath the slide, looks like the rear roller has more weight to it than the front ones.
Thoughts?
Old 08-05-2019, 09:04 PM   #7
Bonjoey's Avatar
This eliminates most of the noise but on low speed the clunk is still there
Old 08-05-2019, 09:31 PM   #8
You need to lube the slide. There is a certain type of spray you use. YouTube has a video on it. I have to do it to my dads Thor MH every now and then. His sounds like something is loose in the wall while you are driving. After you lube it, it doesn't make any noise.
bigmurph is offline   Reply With Quote
Old 08-05-2019, 09:34 PM   #9
Bonjoey's Avatar
Yep did lube it several times and still no change.
slide, sunseeker
